Boz, hotties, end.
Mangs, just got this email from Kingston park for a team challenge race deally on Thursday night.
Kingston Park
Team of 4 tis $80 each for 90 mins of racing. Part of a bi monthly 5 round series. Anyone keen? Need another 3 people to be interested starts tomorrow lol
I'm in.
I am not. Broke as a joke these days. Damn kids.
Plus no longer a fan of go karts, as I am at a serious disadvantage weighing in at a sprightly 120kg.
Just do what I do and make up for it with pure skill and awesomeness
I am just a competetive prick. If only they had a handicap system where they weighed down all the karts to an even weight :)
I could lose some weight, but then there would be less of me to go around. plus I like cheesburger too much
I am quite offended with the ammount of jokes that are made about my condition
I am what I am (in my best popeye voice)
A 120kg stick of a man
Edited by PWND
Miso you buy! Interestingly you can get childrens and full strength version, which is pretty good if you got a toothache
Not sure how I missed this earlier
Already have that. Been rubbing it into their gums to numb them but hasnt helped much
Even tried rubbing it into my ears to numb them, but still no dice
i feel ya. the up side is that the kart wont slide...cornering becomes very easy :)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
