agreed, love those events in a game...but in IRL, i dont think i'd have the balls to even try.
BOZ! did you get your car back yet?
and a simple spark plug question for one and all. the iridiums that are in my car are heat 6 gap 1.1. should i stick with this with the new plugs (prob just coppers)
or go down to a 0.8 gap? my 5000rpm+ stutter is getting worse :( just wondering if it might just be the gap?....or the distance driven with them in.
I'd take water over flipping and fire any day of the week. Unless you have a VERY difficult car to get out of I'd say your chances of survival are higher in a splashdown, more time to react. Both are terrifying situations however.
Upside down, on fire and in the water however...
The one that always has me on edge even watching are the crazy cliff drops on the outside of many European Tarmac rally's or events like Pikes Peak. That's a damn long way to fall with nothing but skill stopping you going over.
and on that topic. i just downloaded a Jeremy Clarkson DVD collection. the first one is Motorsport Mayhem from '99 and i just watched a corolla drive straight down a cliff and end up upside down in water.
No car yet but it must be actually done (or so close it doesn't matter) as Just Car contacted me to pay the excess. Once the payment clears I'm hoping she'll be back in my hands :)
On the topic of spark plugs, I gapped down to 0.8mm on my last spark plug change (about 10,000km ago, they are due for another change soon) and it helped no end. Once I get my baby back she'll be getting an oil change and new plugs straight up, i actually have a bit of space to work on her now, just need to actually buy some axel stands and a jack :P
How much boost you running bodo?
just stock boost, with the low boost bypass job.
copper sparkplugs, smaller gaps, and replace them while doing oil change. costs less than fancy plugs and does the job just fine.
yeah im gonna go coppers, the iridiums do save alot of time as the plugs aren't a 5 min job with standard pipe work, and 5000km was every second month the last few years (thankfully that is no more)
the 6 heat range should be fine then i assume?
Anybody aware of any cheap standard skyline seats for sale? Need some till my fixed back gets here
i got a set of 34 seats cheap at a place called the Panel house in slacks creek, they had all types and sizes there for relatively cheap. my clean pair of 34 seats only cost me about $150
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
