Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
I burnt my pipe last night, if that counts?
In other news,
I was gonna come out last thursday but you know, not driving a riceline and all I would feel left out. Plus, I don't have a hat.
Edited by hylian
Nice nice.
Burnt your fingers yet?
If you burn your fingers your doing it wrong
*twirls pipe*
im soo getting my hat on on thursday
Flat cap ?
Depends on what type :bunny:
Dont worry about not having a riceline.
Geez, i drive a maxima-wannabe. Its not a maxima but isola enjoys arguing that it is.
Get a hat though. And if you can a pipe.
Come out anyway. Jason and I are both big Ford fans. You can hang with us :bunny:
+1
As for type... a genwine old school corn pipe... only the best tobaccerrr for this ollle farmer
Morning Mangs
Keen for hat tipping, keen for pipe (that's what she said)
OMFG I JUST CLICKED THAT 'Kittens in tiny hats' LINK WITHOUT REALISING IT WAS YOUTUBE AND IT WORKED!!! WTFONEONEONEBARBEQUE
Need to start bringing headphones to work I think :D
your at your desk at work at 7:39am
By 7:15 normally. It's by choice though, I do it so my trips to and from work are half an hour not an hour.
sucks to be you
I was going to say no, because I get to go home at 3:15, but then I read this:
ill get to mine around 10, and be home by 3... :D
What do you do btw?
Blocked website at work hey?
Not at mine. I can watch as much p*rn as I like.
granted I work from home though :)
Pootube used to be blocked, but they upgraded the filters recently and it must have slipped through.
Massive fail though, I just clicked on a thread in wasteland and got a big "DENIED! ADULT MATERIAL PRON ETC YOU HAVE BEEN NAUGHTY!!!!" message and now it seems the whole of SAU has been blocked :(
Now I have to use this sh*t slow connection I have h4xed to bypass the filters.
The work from home option is sounding good, I now can't access SAU or my personal email without h4xing, plus I have sh*t small desk. I should be able to a fair bit of work from home soon. At the moment though, I don't have any work suitable for taking offsite :(
What is it that you do that you get to work from home?
account manager
work in wholesale with the major CE retailers and FMCG retailers...
basically been in sales now for 11 years...
Eat a bagel, like a boss... send some fax's, like a boss... etc etc
spose i better go iron a shirt and go to work...
need to stop by the bank and post office etc on the way... might take an hour...
also feel like a HJ's brekkie wrap for some strange reason today... ummmmm
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
