Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Where do people get their licenses from? I nearly got hilux'd this morning crossing the road. Farrk
Same place the Asian chick in a white Getz I saw on my way to work did. She turned left while indicating right... WTF!?!?
Morning Mangs
Yet to be pulled over, or even had a second look. Could be due to when and where i drive, but i think its mostly because the car's bog stock.
I don't get pulled over too often, do get looked at and followed a lot though.
Can some one give me a playing contract so I can go out and muck up and get kicked out of the club. Oh and still get paid out $1mil on leaving.
I will give you a $1/year contract to play the banjo. If you muck up and get kicked out of a club, termination payment will be $1.
Only catch is you have to be good at playing :thumbsup:
That's what she said
Sarp mangs. Sore throat is not so sore. Winrar!
Did the lube help?
fark missed a page :(
3rd last day today. Ducking out early however :)
I'm a big fan of ducking out early
hai guys :action-smiley-069:
so much ot do this week again....
McMarty, get the rom off the board yet?
hai Scottai. Nope, too hard. Did you buy the special tool thingo you were talking about?
Wheat Bix packets. Getting hilux'd can't be good.
*headsplode*
It comes with the car I'm guessing...
I've seen this all too often
Heading down to Jaycar this arvo. Or if you're not fussed on keeping the standard ROM, cut the legs. It will make it hella easy.
Throw in a piece of straw and overalls, and I'll start negotiations with the sister/wife.
hyuck hyuck
They don't. They spend all their money on $100,000 cars with custom plates and forget to buy driving lessons and indicators.
For sale, one set of BMW/Merc/Lexus indicators. Never used, current owner is stuck so far up their own ass that they think that everyone should give way to them automatically in all situations. Will swap for in car entertainment system so I can be even more distracted while running the kids to school.
  • Like 1
That's what she said.
Out of curiousity, link to said tool at Jaycar?
I couldn't care less about the the stock ROM. I did think of cutting the legs off, but my side cutters don't seem to be able to manage it :(. I might trying going in from the 'top' instead of the 'side', if that doesn't work I might just get the dremel out...
hyuck hyuck
A piece of straw I can maybe manage but overalls? C'mon man, I drive a 31... I can't afford overalls.
If I bought a $100,000 car, I'd want it to come with indicators. Just sayin...
I'll give you a fish tank and a mountain bike inner tube.
3.5 hrs
Impressive.
How do you blind an Asian?
Put a windscreen in front of her
No idea on the link. Just gonna roll down there and hope for the best....
I was trying to keep the ROM intact!! If you had of said not to worry, I would have cut the legs off it!
+1 cut legs off with dremel.
Or you can use a heat gun on the reverse side but you need to make sure you concentrate the heat onto the rom and not the surrounding chips
Furry muff... I'm just keen to see what sort of tool you have in mind...
Dow! Communications breakdown :(. If I give it back to you on tursday and tell you it's OK to cut the legs off, how soon can I have it back finished? :)
A supporting vote from the allmighty Dan? Sounds like a goer.
Not so keen on that technique... i'd cook something else for sure...
Annoying thing is I've desoldered heaps of ICs before just using my soldering iron and a solder sucker... this one's just being a right prick for some reason.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
