  • Replies 207
Neons sound good... I am installing an X-box / TV screen / subs / amp / cd player into my car shortly (After timing chain is fixed) and might be after a Small green Neon for above the Xbox in the car... how much for like a 30 cm neon?
MELV,
Thanks for the replacements.... Got them all installed and working today and they look awsome. I will get some photos and post them up soon.
Excelent. good luck with the install. please dont forget to send a photo.
CHEARS
MELV
Hi Melv
Just read through all the posts on this thread and am definately considering doing business with you. Can you send some pics of the aqua and blue through to [email protected] please mate.
Cheers
hey mate if u could send me some pics of blue neons and red if u have them that'd be great, if u can send any others aswell it would be appreciated, i just need to make up my mind about about what colours i want, cheers.
[email protected]
hay melv , got a bright blue line , woundering if you can do yellow as no-one has mentioned it yet , and I am going for a yel/blu theme ? if not pics of other kolors pls to [email protected] . will be in bris vagas in a few weeks so can p/u or come around for a look at least
jaqule, mate we do offer a yellow but the glass is diffrent from the normal (blue green purple red aqua etc) its very very brittle and will break alot easyer and its not as bright. i will send you a email of a few pics i have taken of diffrent colours etc.
Melv,,,I stickied your thread cause I thought it would help everybody who wanted neon's. Now I would like you a donate a bit of your profits to keep this place going. If you can,,,then please contact PranK.
Thanks
Neil.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
