  • Replies 188
Ok, so just recapping...
Start: 8:15 (on pan by 9am)
Finish: 5pm (at the Arms for debrief by 5:30)
Cost: $100 for the day (Cheap)
No hemult needed
One passenger allowed at a time (do they have to pay or just sign a form?)
Long pants and covered shoes required, long shirt optional.
Instructors on site.
Lotsa sideways fun... Guaranteed?!!!
Only one week to go... I'm SOOO excited already... hope it doesn't rain all week... :(
OK, 50 preople ready to rock. I think we can have maybe 2 or 3 more, with the assumed 5% no shows.
Oz
321_go
321 Friend Shane VL
Blitz
Kinks
Flip
Akira
Endorean
B-Man
Majanal
Majanal friend Rhys
Lozza150
Slo200
Slo200 Friend Datsman
Telej
moemoe
Listen 180SX
TonyGtst
Eav001
GTR-8OY
Dave CWH-08U
BBenny
BBenny Friend Ribbo
BBennt Friend XXX
Pro_32
Zane 1/2 Day Morning
Fatz
Caferacer
Tonkotsu Flavour
Crazy 180
Stuart (STUGTR)
Tony
Arthur
Mark
Ned 1/2 Day Morning
Ned friend xr8 1/2 Day Morning
Nathan
Zaero
Abo Bob
Bakadesu
Backup
(Silvia)Zman
(Silvia) Crazy 180 Grey spec
(Silvia) Crazy 180 yellow spec
(Silvia) Nisom 180
(Silvia) Quacker
(Silvia) Boxhradmr
(Silvia)16a6w6s6
(Silvia) Pro.180
Schmango
Reedy
Guys I have to pull out, as stupid as it sounds I need the dollars for the global concert that night with carl cox, cypress hill and freq nasty...
I will still be there, taking photos and checking out your cars but I won't be getting it sideways *cry*
"a man with priorities so far out of whack doesn't deserve such a fine automobile" - Ferris Bueler
Gents,
There is some room in the the arvo seccion, and yes 1/2 day 1/2 price.
Listen 180, I will put you down as a 1/2 day, arvo slot only.
Darkwave, you sucker, your back on the list.
Enilyks, You are on the list no probs.
Maj, Get them to turn up in the Arvo and I should be able to get them on. I have about the 3 slots left in the 1/2 day arvo.
OK, 53 preople ready to rock. I think we can have maybe 1 more, with the assumed 5% no shows.
The names are: Drum roll please
Oz
321_go
321 Friend Shane VL
Kinks
Flip
Akira
Endorean
B-Man
Majanal
Majanal friend Rhys
Lozza150
Slo200
Telej
moemoe
Listen 180SX
TonyGtst
Eav001
GTR-8OY
Dave CWH-08U
BBenny Friend Ribbo
BBennt Friend XXX
Pro_32
Fatz
Caferacer
Tonkotsu Flavour
Crazy 180
Stuart (STUGTR)
Tony
Arthur
Mark
Ned 1/2 Day Morning
Nathan
Zaero
Abo Bob
Bakadesu
Backup
(Silvia)Zman
(Silvia) Nisom 180
(Silvia) Quacker
(Silvia) Boxhradmr
(Silvia)16a6w6s6
(Silvia) Pro.180
Schmango
Reedy
Dark wave
Enilyks
Listen 180 1/2day arvo
Maj friends 1/2 day arvo
GTR-8OY friend Orhan Com
GTR-8OY friend Murat soarer
Se you all brign and early on Sat morning.
Thanks Oz
