Hey V35_Paul did you install or get installed the plenum spacers? how is it since? I'd like to do it too.
Also I've been trying to get headers for my V35 and I was going to get them through C-Red who did the install to his own V35 before he sold it, but I havn't been able to get in touch with him to get some.
Can anyone recommend where etc I can get a set and who could install them around Perth?
  • Replies 143
Posted Images
Got my Spacer but yet to put it on. I'm doing a Dyno test before and after. I'm on the Dyno friday at 3 for the before test.
I also heard that you need to put the spacer on when the car is cold and that the computer "might" need running time to adjust to the spacer so i will do the after test monday.
I'll put it on myself doesn't look to hard.
Found this on Ebay http://cgi.ebay.com.au/Stainless-Steel-Exh...p3286.m20.l1116
don't know anything about it
Lots of Headers in US
Well I did the dyno test. My car is "Stock". Did 3 runs, I got 163kw on 2 runs and 162kw on one.
I couldn't put the Spacer on becasue the car is too hot, I'll put it on tomorrow then do another run on monday.
Here are my results of my best run
More problems with my Body kit. need clips for the side skirt. i'm going to try some plaster board cross screws. (When you screw them the back stars out and pulls tight) They are used to hold A/C up on plaster walls.
if it works i'll have my car back today looking super cool. (it was already cool before but now it's SUPER)
All done. Now i can stress less.
Body kit looks good, still need to put a badge on the grille, badges on the skirts and fog lights.
Tell me what you think, do you like it or should i have got something else?
pics with the phone
  • 1 month later...
Hey WA V35 owners.
Thought i would try and find out how many WA V35's there are.
Post a pic (if you got one) and count off.
(1)
hey im a new member from WA Ipost-63076-1243175761_thumb.jpgv had this ride for about 4 months and i love it its a 2003 v35 GT 6 speed manual hope ya all like
  • 1 year later...
its an old thread but seems to me that some have come and gone... can we do a count of who in wa actually uses this forum
1.xtc - please add along...this will give me an idea or indication to do the next cruise as i want as much members out there as possible, and a good notice.
hey guys im ultra new..... just got my V last wednesday, hit the pits on friday and cleaned it up on the weekend
so yeah, i have been keeping an eye on this site for a while
Good to see that there are some V lovers in Perth
Im learning new things about my Beautiful car every day :P
Hope to see you on the streets some time, unfortunatly i work alot and get pretty busy doing ... well not doing much but
im glad that there are others in WA to help me out if ive got issues and..... i doubt it but if need be i may be able to assist you all :P
ill try and stay active
but im notoriously bad at using the internets
POST NO#1 COMPLETED! (bows)
now.. how do i send thisssss.......
Its a blue one xtc, not quite as sexy as yours (yet) haha, after polishing it up it seems to have a pearlieishie quality YAY !
doubt ill get to your lvl of mods but i will keep tinkering away at it who knows... thats what they all start saying next thing i know ive got a green car with fluro orange rims and a biplane wing on the back
errr... i think i just vomitted in my mouth. You can be assured i would never do that too my precious V.
oh and thanks for the warm welcome Crisp =D
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
