  • Replies 69
Sorry guys, so many questions..........
GT1 first , http://www.hioctaneracing.com.au/
We use them (as Performance Metalcraft) for fabrication when our team fabricator is too busy or away. They do top work.
Rev210, they have Tomei camshafts in stock. Sorry my cattledog is at work.
Inasnt, yep the Tomei Poncams are designed to work with VVT. Don't bother with an adjustable exhaust pulley they are pretty much spot on standard, spend the money on something else.
Hope I answered everbody
Rev - I think this is the mildest:
Tomei Cams 256 duration and 8.5mm lift compared to standard 240and 7.8mm lift
That's what I am putting in my car during re-build
YEs, I understand they work with the std hydro lifters - I'm not changing mine anyways - Unless the head people do that without me knowing about it.
Price - Well, I think I'm paying a bit more than normal - but I'm also getting a package deal and make up for it on other things - So you should be able to get better then $1200-1300 - Cheaper if you import yourself (But not quicker) you pay a premium for off the shelf stock on Oz......
Hi INASNT, if you mean "headwork" as in clearancing to fit the camshafts (not porting) then duration is basically irrelevant, lift is the issue. When we get the lift over 9 mm, we die grind the head to clear the lobes. Pretty simple, you can do it in the car as long as you clean up properly afterwards.
So to answer your question we have run 292 @ 9 mm without "headwork". We also have run 264 @ 10.5 mm and done headwork.
To answer the second question, based on my personal experience;
240 is standard GTST
248 is standard GTR
256 is a good mild street upgrade, go for 9 mm lift
264 is a good combo (street, track, circuit) go for 10 mm lift
272 is a good for circuit work at 10.5 mm lift
Anything more than that requires a big turbo/turbos to use it, to get the best a close ratio gearset or an auto would be my suggestion.
There are plenty of people running around with more than the above, but they don't seem to keep the car very long. They get there jollies from the doing (or the bragging) rather than the driving.
Hope that helps
  • 5 months later...
Hey guys
does anyone know how a HKS step 1 (I think they're 256 whoops I meant 264) exhaust camshafts would go with the standard inlet Camshaft?
being step1 I heard they're ok for on the street, but would they work with standard inlet cams?
Also any ideas where I could get the stock exhaust Cams?
Im having no luck here in WA
I'm confused, I have seen 256, 260 and 264 described as "Step 1". Plus I have 264 described as "Step 2". So I just call them 256, 260 or 264, "Step" is a useless term.
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
