Dont use normal VAC line, because its for VAC (name says it all) it can split under high boost, its happened to me before twice.
Turbosmart make good silicon hose, 4 and 6mm, find a dealer, ET Performance have it, comes in blue and black so youre set.
https://www.sau.com.au/forums/topic/261699-vac-line/#findComment-4486081
where are they?
https://www.sau.com.au/forums/topic/261699-vac-line/#findComment-4486655
The bigger is approx. 6mm internal diameter and 87cm/34inches long. The smaller is approx. 4mm internal diameter and 87cm/34inches long. They're from my HKS EVC 6.
so would suit my EVC 4 from the sound of things :P
i added you on msn, will try and grab it soonish unless it gets installed at the service on the w/e
https://www.sau.com.au/forums/topic/261699-vac-line/#findComment-4487932
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
