if you are upgrading to get more resolution check out the Nismo AFMs
they are a Z32 sensor inside a 65mm shell so you get the benefit of more resolution
from the same size shell and plugs so its a direct swap and select Z32 AFMS in your ECU management (ie PFC)
otherwise if you fit 80mm ones you have to change ducting, pipework, intake and plugs
https://www.sau.com.au/forums/topic/261896-80mm-afm-on-gtr/#findComment-4487973
i just got a PFC not long ago then had AFM problems >.<
epic fail.
i was going to switch to Z32s for the price :)
apparently the 80mm with some force will fit into the stock rubber hosing to the turbos. its just the AFM attachments you need to figure out.
https://www.sau.com.au/forums/topic/261896-80mm-afm-on-gtr/#findComment-4488178
    • I've got a 2011 J50 that I imported six years ago. The unmodified factory AV system date and time has always been correct ( Japanese timezone of course ) up until last month. About two weeks ago, at engine start, the system wished me a happy new year ( in Japanese of course ). I can't think of anything that would make the system think that the date had changed, unless the GPS component has failed/reset somehow ? I checked the GPS reception in the system settings, and it can still see the satellites. Has any other J50 owner had this happen ?  It's no biggie, just annoying that it tells me the wrong date anytime I start the engine. 😅
    • Love following your adventures on IG, hopefully if you're still around in Japan when we visit again wouldn't mind going for a few beers with you (that's if you're keen on hearing how I hate Nissans).
