For sale:
1x rb25det 5spd manual gearbox
Condition:
72500km's(as indicated on the frontcut) i have not driven on this gearbox however considering the condition of everything else im very confident its in excellant condition
Price:
$1450
Info:
Gearbox comes with a complete shifter including a slightly worn standard gearknob, good condition gearbox mount & crossmember, Standard Clutch slave cyclinder, i have the harness that connects up to the box aswell somewhere, i plan on finding that today
i can supply photos upon request however... its a 5spd r33 box if you've seen one... you've seen them all in my opinion.
Contact Details:
- I WILL NOT answer private numbers, txt msg's... would prefer phone call, if i miss your call please do not leave a msg(i dont know how to turn the f*kn mailbox off!#%!@#) i will call you back when i see the missed call
I am located in Cairns, will freight at buyers expense(if in qld should be able to organise it at a reasonable price)
Edited by R31Nismoid
https://www.sau.com.au/forums/topic/261923-r33-parts/
For sale:
R33 Dash
Condition:
excellant, will hopefully have pics up this afternoon/tonight, all aircon vents are in perfect working order, will supply all the panels that go with it and around it, the only thing not included is the cluster itself, manual shifter surround and ash tray, ciggie lighter
Price:
$550ono
Contact Details:
Cairns Will freight at buyers expense
https://www.sau.com.au/forums/topic/261923-r33-parts/#findComment-4488116
For sale:
R33 gtst radiator
Condition:
Came out of a front cut i bought i believe it has been recored recently or flushed as it is in extremely good condition and to look inside the tanks.. you'd think it was new
Will have pics up tonight hopefully.
Price:
$200ono
Contact Details:
Please Pm me here,
https://www.sau.com.au/forums/topic/261923-r33-parts/#findComment-4488117
you dont need 3 threads, for 3 parts. Merged.
someones cranky, did it really matter if theres 3 threads??
incase anyones curious about the gearbox freights 50 to brissy areas, and 65-70 to sydney areas.
not to mention thanks for f**king up the posts where i'd bumped and had a price change. now its all f**ked up and out of order and i cant even edit the posts.. thanks again.
Edited by Cartman
https://www.sau.com.au/forums/topic/261923-r33-parts/#findComment-4501192
What exactly is included in the dash? Is it s1 or s2?
If its the just the dash surround that goes around the stereo and has the 2 middle aircon vents in it, that part usually goes for $50 so im not surpirsed u've had no offers.
Also Gearboxes with warranty now go for around 1200-1300. Thats what i was quoted in Melbourne anyway. Of course u can ask any price u want but i thought i'd give u the heads up as to why you havent had much interest
https://www.sau.com.au/forums/topic/261923-r33-parts/#findComment-4502309
dash is series 2, its the COMPLETE dash, comes with glovebox and all the little panels that bolt on/clip on... everything except for the cluster which is why ive put the price i did on it..
tell me where it is that goes them for 1200-1300, and incase you didnt notice im open to offers o n all of them.
Edited by Cartman
https://www.sau.com.au/forums/topic/261923-r33-parts/#findComment-4502464
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
