For sale:
1x rb25det 5spd manual gearbox
Condition:
72500km's(as indicated on the frontcut) i have not driven on this gearbox however considering the condition of everything else im very confident its in excellant condition
Price:
$1450
Info:
Gearbox comes with a complete shifter including a slightly worn standard gearknob, good condition gearbox mount & crossmember, Standard Clutch slave cyclinder, i have the harness that connects up to the box aswell somewhere, i plan on finding that today
i can supply photos upon request however... its a 5spd r33 box if you've seen one... you've seen them all in my opinion.
Contact Details:
- I WILL NOT answer private numbers, txt msg's... would prefer phone call, if i miss your call please do not leave a msg(i dont know how to turn the f*kn mailbox off!#%!@#) i will call you back when i see the missed call
I am located in Cairns, will freight at buyers expense(if in qld should be able to organise it at a reasonable price)
Edited by R31Nismoid
https://www.sau.com.au/forums/topic/261923-r33-parts/
For sale:
R33 Dash
Condition:
excellant, will hopefully have pics up this afternoon/tonight, all aircon vents are in perfect working order, will supply all the panels that go with it and around it, the only thing not included is the cluster itself, manual shifter surround and ash tray, ciggie lighter
Price:
$550ono
Contact Details:
Cairns Will freight at buyers expense
https://www.sau.com.au/forums/topic/261923-r33-parts/#findComment-4488116
For sale:
R33 gtst radiator
Condition:
Came out of a front cut i bought i believe it has been recored recently or flushed as it is in extremely good condition and to look inside the tanks.. you'd think it was new
Will have pics up tonight hopefully.
Price:
$200ono
Contact Details:
Please Pm me here,
https://www.sau.com.au/forums/topic/261923-r33-parts/#findComment-4488117
you dont need 3 threads, for 3 parts. Merged.
someones cranky, did it really matter if theres 3 threads??
incase anyones curious about the gearbox freights 50 to brissy areas, and 65-70 to sydney areas.
not to mention thanks for f**king up the posts where i'd bumped and had a price change. now its all f**ked up and out of order and i cant even edit the posts.. thanks again.
Edited by Cartman
https://www.sau.com.au/forums/topic/261923-r33-parts/#findComment-4501192
What exactly is included in the dash? Is it s1 or s2?
If its the just the dash surround that goes around the stereo and has the 2 middle aircon vents in it, that part usually goes for $50 so im not surpirsed u've had no offers.
Also Gearboxes with warranty now go for around 1200-1300. Thats what i was quoted in Melbourne anyway. Of course u can ask any price u want but i thought i'd give u the heads up as to why you havent had much interest
https://www.sau.com.au/forums/topic/261923-r33-parts/#findComment-4502309
dash is series 2, its the COMPLETE dash, comes with glovebox and all the little panels that bolt on/clip on... everything except for the cluster which is why ive put the price i did on it..
tell me where it is that goes them for 1200-1300, and incase you didnt notice im open to offers o n all of them.
Edited by Cartman
https://www.sau.com.au/forums/topic/261923-r33-parts/#findComment-4502464
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You don't need to drain the intake heat exchanger to remove the radiator but depending on your plans you may need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
