have had a slight miss for quite some time, but it has only been evident inconsistently at idle and hot whilst driving.
decided to get off my ass and change the plugs which i had not done so since getting the car and it has done over 15,000kms since then. while i was there i did an oil/oil filter change as well.
so, changed to NGK copper heat range 6 and the problem got worse? what i seem to think is that the plugs have improved spark and this just exentuates the same problem rather than making it worse.
So i then reset the ECU and cleaned the AFM and a little bit better but still noticeably there.
what do you guys think?
i was thinking:
- clogged injector
- stuffed coil
is it worth chucking a bottle of injector cleaner in? or is that stuff bad?
please help!
Waz.
https://www.sau.com.au/forums/topic/26193-missing-problem-plz-help/
my car was missing, I took it in for a full service and for 'em to check this problem, they said one of my coil packs was not working properly and the timing was a bit off.
They fixed the timing, and no more missing!
maybe that might be the go for you...
0.8mm
i just checked the timing the other day and set it to 20deg so i doubt that would be hte problem
its very inconsistent. ie sometimes it will happen more and sometimes less. and i can't hear of feel anything when accelerating. that's why i'm thinking injectors.
oh, and at cold start the problem is pretty much non-existant only when the car warms up.
HELP!
Injectors can be cleaned at an EFI specialist, they clean them with a ultra-sonic method. (For more info on servicing injectors http://www.cruzinperformance.com/injsteps.html)
Although injector cleaner (fuel tank use) might show improvement its not as thorough as the ultra sonic method.
I had mine cleaned and tested and it turns out one even after cleaning only did 90mls to the 100mls. I changed the injector and fixed mine from missing at idle and cruisin.
MEGA
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
