Hey all,
The Bosch fuel pump group buy is back on again, Starts today and ends on the 18th of April.
Genuine Bosch 044 external fuel pump $220 delivered
Rated at 200 Litres per hour @ 5 bar
Inlet Connection M18X1.5
Outlet Connection M12X1.5
Genuine Bosch 040 internal fuel pump $220 delivered
Rated at 102 Litres per hour @ 6.5 bar
We need a minimum of 8 people. The orders will be submitted at 5pm 19/4.
Flow ratings and specs
They are genuine Bosch items made in the Czech Republic.
Supplier of all fitting, one way valves, braided lines can be purchased online from www.mscn.com.au they are located in Seven Hills NSW talk to Mark..
Post here or PM me if keen.
Cheers,
Johno
  • Replies 43
of course it is...they max out at 350awkw though.
Great yeah i just heard a stupid remark from my local jap performance supplier today saying it cant be done as i paid and had installed my o44 in tank and was told no you wouldnt have one of these.
Thanks for clearing that up i was going to get on the phone and blast my installer.
cheers.
I'm interested. The 040 is in tank and is the same price as an 044 which can be used in tank as well?? What sort of flow rate does the standard OEM item have? Is there any reason I shouldn't just get an 044 and put it in the original tank position or are there headaches involved as opposed to the straight fit 040?
Any help appreciated, let me know payment details when I have these answers.
Cheers
The 044 was designed to be used externally, it can be used intank with a few modification to the cradle. More info on how to install the 044 as an internal can be found here:
http://www.skylinesaustralia.com/forums/Bo...ml&hl=bosch
Yes they are the same price, to be honest I dont know the flow rating for the standard items. Maybe someone can help with this answer?
Payment details will be sent once we have enough people interested.
Cheers
Johno
whats the best pump for a r34gtt.??
depends on the power your making mate, if standard then the 040. If your standard pumps not playing up 'l just leave it in there. no need to 'upgrade' if you dont need to.
Is it any cheaper if i got 2 044 external pumps? Need to be able to support 450-500kw.
Sorry mate, prices are per item..
Cheers
Johno
I have an R33 GTS-t, i want to up grade but only looking for 270kw max. i want a striaght fit will the 040 handle this power?
Cheers
The 040 is not a direct replacement, you need to modify the pump cradle, here is guide how to do it, if you want a direct replacement then go with a nismo but be prepared to spend about $300-500.
Too easy, thanks aberax that is correct. To fit internally you will need to modify the cradle. There is also a direct 12v DIY that I suggest you do at the same time.
Im also looking at replicating a surge tank perspex casing to suit twin 044's similar to the one Dirtgarage had. would anyone be interested in this? im not sure of costs yet just something im looking at for my car.
Cheers,
Johno
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
