As the title says, set of 4 x Falken Ziex ZE-326 225/40ZR18 up for sale.
Lasted about 5000km on the car. The tyres still have +90% tread left, and are a good tyre.
I no longer have a car to put them on, so they are just taking up valuable space in the garage.
Looking for about $400 for them, will consider reasonable offers. They are at least $600 to replace with new.
Prefer local pick-up or drop-off.
Contact Jason on 0418761866 or pm on the site. Will try and check back here as much as possible
https://www.sau.com.au/forums/topic/262018-18-tyres/
