i have an r32 with a pretty freshly built motor
only done 10,000 kms making decent power
i just had my gear box changed to the r33 box recently.
as i just got the car back it hasnt been running perfect since.
i must admit ive been thrashing it lately to try out the new box
but anyway it is missfiring at idle and low revs. also has a bit of blow bye??? but engine is new???
i looked into it a bit more to see what was wrong and i had notice lately that my oil gauge in my dash
was only reading 2kg/cm its usualy around the 4kg mark or more
so i checked oil and there is none???? how much does a car use up??
do you need to drain oil when a new gear box is installed? maybe mechanic forgot to put some back in??
i dont get it car was serviced 5000km ago... if there is no oil could that cause exessive blow bye???
and the missfire??
my car doesnt blow smoke or anything and i cant see any oil leaks apart from one where a hose is just loosely fitted
im so bloody worried now that ive caused damage to my engine...
please help
No engine oil at all ?Hmmmmm... or only a little bit left ? I would be getting a compression/Leakdown test performed ASAP. Top up the oil before you even attempt to start it. Sometimes cars with Forged pistons use a " little " amount of oil but not like the amount you are describing. Get the Compression test done .That will give you more info
Not good. I would be very closely monitoring that dipstick. Check it at least once a week until you get the car to the mechanics. last thing you want is to starve the engine of oil, Spin a bearing and bang totally lunch your engine
New engine. You will get some oil comsumption in the first few thousand k's, due to rings bedding in etc, then they usually settle down.
Just gotta keep tabs on the oil level.
A 10w 40 oil should be okay to use or whatever the engine rebuilder suggests.
Gook luck with it.
my recommendations
1) see a mechanic before playing
2) see a mechanic before playing
3) see the mechanic who did the engine build before playing
lastly check the oil level, any std 10w40 or 5w40 should be fine, the first digit identifies how long before the oil rushes to the head when you turn the key
so 5 or 10 is ok - wont be a massive difference. when the engine is warm at idle, oil pressure should be 2kg/cm2 on the standard pressure gauge
if you had no oil pressure guage would show 0 and engine would cease up guaranteed
idiot light would also be on so its unlikely there is NO oil in the engine, but low is possible (again less oil, means more pressure, which would show on the guage)
ie - you shouldnt have 5kgcm2 oil pressure at idle, and you shouldnt have 1kgcm2 at idle either (this is when engine warm)
there was like no oil on the bottom of the dipstick once i cleaned it and put it back in for a few seconds and pulled it out again
and the engine was warm
it possibly sounds like another engine with the rings put on upside down as a 5000klm old engine should not still be using oil at that rate for the next 5000klm.
how often did you check the oil level?.
Edited by DiRTgarage
went to see the mechanic today he reckons it is fine and im streesing for nothing
i checked the oil often in the first 5000kms like every second day
it seemed fine not much oil consumption as far as i know
i had it serviced and ive done about 4500kms i thought there would be no way the oil would be low its only done 4500kms
i only checked it because the oil gauge was down to 2kg/cm2 its usually 4kg/cm2 when driving under load
so because of the missfire i had that was only at idle i started to look at it more
checked plugs to see if everything was connected ok and i took off the breather pipe
to my catch can and under bright light i can see the air particles coming out IS THIS NORMALl???
the catch can fills up with sorta like water not exactly oil.
mechanic said thats just condensation at startup when cold
told me its normal also
the filter also on the catch can soaks up with oil and if you touch it you can see its definately oil
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
