ok so i bought JUC33Y (an s15) for those who may or may not have heard. Out of about 7 s15s that i looked at this was the cleanest, and by no contest the quickest car of them all. I have only owned the car for about 2 weeks, however after having driven it to uni in the city for the past 2 weeks I find that this car is not suitable for the driving that i do, and VERY regretfully i must put it back up for sale. I seriously think this is one of the quickest 2 litre s15s in sydney and has been properly built by Croydon Racing Development with no shortcuts taken (wait till you see the receipts!)
I recommend this car for someone who is looking for a bulletproof machine, which will literally tear the balls off the driver, and any passengers who are lucky enough to sit in this thing. This is by far the fastest car i have ever driven (and i have driven quite a few cars!) and would not recommend this for someone who has never owned a high powered turbo car before (i have had 3 200kw+ turbo cars before in my life, and this car still scares the bejesus out of me....on low boost). I am currently driving around with it on 15psi, as frankly im too scared to drive it on higher boost and 15psi is more than enough for the street.
In my very short period of ownership i have done the following:
New plates, new gearboot surround (clips were broken in the old one, and new wheels with new tyres. I dont see a need to change anything else with the car as it is what id consider the ultimate street machine (unless you want coilovers etc which i was considering but decided against).
here are some details as per previous owners ad (very helpful bloke who only sold because he is having a baby):
Selling my 2002 S15. cars done 135,000kms (12/03/2009)
Receipts for all work done, totalling over $43,000. yes there has been over $43 000 spent on this car, with receipts to prove. seriously, $43,000 with receipts.
Car also comes with genuine factory log books, manuals and STAMPED service history! Both genuine keys and alarm controls (QuikTrack Fitted)
New Motor, Gearbox and Diff set-up only done Max 10,000kms.
Motor, Box and Diff all done by Croydon Racing Development, all with reciepts and Dyno Sheets (280rwkw....yes....seriously 280rwkw)
Drives absolutley Great , Very fast Car. and very Taken care of. Bought the car 3yrs ago with 90,000km, so ive only done 45,000km in 3 yrs, mostly Highway driving to work and back (M4). Car definately reflects this, interior is immaculate, and the exterior paint is all original and also in very good condition (apart from your occasional car park dings), definately more of a highway car, and i would not recommend it to someone who will be constantly commuting in heavy city traffic (Very recommended for someone who has a daily, unfortunately my parents wont let me buy one as they see it as a waste of money).
Engine: SR20DET
Exhaust: Fujitsubu Power Getter Cat Back. Trust Pipe Turbo to Cat
Suspension: Stock - prev owner had coilovers in then changed to standard shocks and springs (only 40 000kms ~ on these shocks, car still sits very firmly on the ground and no noise from the shocks at all)
Wheels: Buddyclub P1 racing II plus in gunmetal grey with a polished lip, 18" wheels sitting on 265 pirelli tyres. (This car needs fat tyres to keep on the ground....seriously 280rwkw)
Modifications:
ENGINE
Trust Airinx Filter
Trust TD06 SL2 running 15psi, 18psi and 20psi (used to achieve a breakneck 280rwkw)
Trust HighMount Manifold
Trust Front Pipe
Trust External Wastegate
Trust Screamer Pipe
Trust Intake Plenum
Trust Type RS BOV
High Flow Cat
Fujitsubu Cat Back (power getter)
Hybrid Intercooler
70mm Throttle Body
Z32 Air Flow Meter
Forged CP Pistons and Rings
ARGO I-Beams Con Rods
ACL Bearings
Trust Metal Head Gasket
GTi-r Oil Pump and Spacer
ARP Head Studs
Bronze Valve Guides
Trust Camshafts (in256 ex264)
Trust Rocker Stoppers
Trust Sump
Nismo Engine Mounts
Trust Air Diversion Plate
Nismo Radiator Cover
DRIVETRAIN
RB25 Gearbox
OS Giken Twin PLate Clutch (would recommend you do some left leg workouts before looking at this car, this car means business, and is not for the faint hearted or legged)
Single Piece Tail Shaft
R33 Final Drive (4.11 Ratio)
Nismo 1.5way TT Pro LSD Centre
R33 Rear Axle Shafts
Custom Clutch Master and Slave Cyinder Set Up
FUEL/ELECTRONICS
Sard Adjustable Reg
Sard 850cc Injectors
Bosch 044 Fuel Pump
Apexi Power Fc
Trust Pro-fec B Boost Controller
Spitfire Ignition Coils
Apexi Turbo Timer
BRAKES/SUSPENSION
RDA Front Rotors
Project Mu Pads All Round - Brakes are still like new, heaps of meat left (high temp pad so they are a little noisey, but this car needs them!)
25mm Spacers on From
30mm Spacers on Rear
Front Strut-Brace
Stereo Audio / Visual:
7inch Pioneer Double Din DVD Player
4 x 4ways 6inch Pioneer Speakers
Power: 278.00rwkw @ 20psi
Here are some pics. note the wheels and plates are not yet on the car as I am yet to pick them up, however they will go with the car (along with the stock wheels and tyres)
Dyno chart - note this is a 5th gear pull (i.e. top gear, it will make more on a 4th gear run which is normally used to do dyno runs)
car is a sleeper by all means
plates on order
Immaculate interior, not at all reflecting the age of the car (looks like a 30 000km car inside), as you can see from the pics
and finally, the powerplant, please use caution when looking at the right hand side, turbo may cause eyes to pop and jaws to unhinge
For more pics see here QIK515 Photo Album
Ok so now that you've seen snippets of what the car looks like we can get down to business.
My asking price for the car is $27 500 FIRM. this includes the wheels plates yada yada. please do not make comments on price etc, as i have receipts totally over $43 000 spent on this car not including the purchase price, and it is a bargain for anyone in the market looking at getting a high performance motor vehicle (yes i shall reiterate again...280rwkw...no joke)
THERE will be absolutely NO test drives until a holding deposit is made, frankly because the car is a machine and i do not want people getting hurt (by people i also mean small children on the side of the road who may be sucked up by the massive TD06). I will drive the car before a deposit is made, and only if i deem the buyer serious enough to leave me a deposit afterwards.
Finally, to sum up, this car has been a well cared for, properly built street machine. I do not recommend it to people who commute in heavy city traffic (reason why i am selling), however for those who are able to truly enjoy this car, this purchase will represent the smartest economic move you will probably ever make (selling price is less than half the cost of a decent s15 + mods). It is not for the faint hearted and i will not let it go to a p plater (yes because it has....280rwkw).
I will also consider a trade for something which is more city traffic friendly. i want an s2000, however may consider other trades depending what you have. I am sure the first to see this car will buy it and i suggest you look around at other s15s before looking at this one so you have something to compare to.
If you have any questions, please dont hesitate to call or sms me on 0431 083 394. This car is a dream to drive (if not in city traffic) and has had alot of blood sweat and money put into it (the first two donated by the team at Croydon Racing Development, renouned SR20 specialists).
John 0431 083 394
How much power does this thing make lol
Nice car, fair price, although more than doubling the power from the factory and leaving suspension and tyres untouched does not constitute a properly built street car.
For those of you considering, 278rwkw is NOT scary in a daily driven S15 lol.....I put 230,000kms on my S15 making 259rwkw, drove it around 8 hours a day as a company car, in fact its still being raced around Sandown and Phillip Island.
Good luck and free bump
thanks lol. car makes 280rwkw.
suspension and tyres have been fixed now, and can be factored into the price. car currently sits on custom buddyclub p1s 18X9" rears on 265 pirelli rubber.
also suspension has been changed to zeal b6 coilovers with swift springs. car is basically complete. very fast car in immac condition
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
