ok so i bought JUC33Y (an s15) for those who may or may not have heard. Out of about 7 s15s that i looked at this was the cleanest, and by no contest the quickest car of them all. I have only owned the car for about 2 weeks, however after having driven it to uni in the city for the past 2 weeks I find that this car is not suitable for the driving that i do, and VERY regretfully i must put it back up for sale. I seriously think this is one of the quickest 2 litre s15s in sydney and has been properly built by Croydon Racing Development with no shortcuts taken (wait till you see the receipts!)
I recommend this car for someone who is looking for a bulletproof machine, which will literally tear the balls off the driver, and any passengers who are lucky enough to sit in this thing. This is by far the fastest car i have ever driven (and i have driven quite a few cars!) and would not recommend this for someone who has never owned a high powered turbo car before (i have had 3 200kw+ turbo cars before in my life, and this car still scares the bejesus out of me....on low boost). I am currently driving around with it on 15psi, as frankly im too scared to drive it on higher boost and 15psi is more than enough for the street.
In my very short period of ownership i have done the following:
New plates, new gearboot surround (clips were broken in the old one, and new wheels with new tyres. I dont see a need to change anything else with the car as it is what id consider the ultimate street machine (unless you want coilovers etc which i was considering but decided against).
here are some details as per previous owners ad (very helpful bloke who only sold because he is having a baby):
Selling my 2002 S15. cars done 135,000kms (12/03/2009)
Receipts for all work done, totalling over $43,000. yes there has been over $43 000 spent on this car, with receipts to prove. seriously, $43,000 with receipts.
Car also comes with genuine factory log books, manuals and STAMPED service history! Both genuine keys and alarm controls (QuikTrack Fitted)
New Motor, Gearbox and Diff set-up only done Max 10,000kms.
Motor, Box and Diff all done by Croydon Racing Development, all with reciepts and Dyno Sheets (280rwkw....yes....seriously 280rwkw)
Drives absolutley Great , Very fast Car. and very Taken care of. Bought the car 3yrs ago with 90,000km, so ive only done 45,000km in 3 yrs, mostly Highway driving to work and back (M4). Car definately reflects this, interior is immaculate, and the exterior paint is all original and also in very good condition (apart from your occasional car park dings), definately more of a highway car, and i would not recommend it to someone who will be constantly commuting in heavy city traffic (Very recommended for someone who has a daily, unfortunately my parents wont let me buy one as they see it as a waste of money).
Engine: SR20DET
Exhaust: Fujitsubu Power Getter Cat Back. Trust Pipe Turbo to Cat
Suspension: Stock - prev owner had coilovers in then changed to standard shocks and springs (only 40 000kms ~ on these shocks, car still sits very firmly on the ground and no noise from the shocks at all)
Wheels: Buddyclub P1 racing II plus in gunmetal grey with a polished lip, 18" wheels sitting on 265 pirelli tyres. (This car needs fat tyres to keep on the ground....seriously 280rwkw)
Modifications:
ENGINE
Trust Airinx Filter
Trust TD06 SL2 running 15psi, 18psi and 20psi (used to achieve a breakneck 280rwkw)
Trust HighMount Manifold
Trust Front Pipe
Trust External Wastegate
Trust Screamer Pipe
Trust Intake Plenum
Trust Type RS BOV
High Flow Cat
Fujitsubu Cat Back (power getter)
Hybrid Intercooler
70mm Throttle Body
Z32 Air Flow Meter
Forged CP Pistons and Rings
ARGO I-Beams Con Rods
ACL Bearings
Trust Metal Head Gasket
GTi-r Oil Pump and Spacer
ARP Head Studs
Bronze Valve Guides
Trust Camshafts (in256 ex264)
Trust Rocker Stoppers
Trust Sump
Nismo Engine Mounts
Trust Air Diversion Plate
Nismo Radiator Cover
DRIVETRAIN
RB25 Gearbox
OS Giken Twin PLate Clutch (would recommend you do some left leg workouts before looking at this car, this car means business, and is not for the faint hearted or legged)
Single Piece Tail Shaft
R33 Final Drive (4.11 Ratio)
Nismo 1.5way TT Pro LSD Centre
R33 Rear Axle Shafts
Custom Clutch Master and Slave Cyinder Set Up
FUEL/ELECTRONICS
Sard Adjustable Reg
Sard 850cc Injectors
Bosch 044 Fuel Pump
Apexi Power Fc
Trust Pro-fec B Boost Controller
Spitfire Ignition Coils
Apexi Turbo Timer
BRAKES/SUSPENSION
RDA Front Rotors
Project Mu Pads All Round - Brakes are still like new, heaps of meat left (high temp pad so they are a little noisey, but this car needs them!)
25mm Spacers on From
30mm Spacers on Rear
Front Strut-Brace
Stereo Audio / Visual:
7inch Pioneer Double Din DVD Player
4 x 4ways 6inch Pioneer Speakers
Power: 278.00rwkw @ 20psi
Here are some pics. note the wheels and plates are not yet on the car as I am yet to pick them up, however they will go with the car (along with the stock wheels and tyres)
Dyno chart - note this is a 5th gear pull (i.e. top gear, it will make more on a 4th gear run which is normally used to do dyno runs)
car is a sleeper by all means
plates on order
Immaculate interior, not at all reflecting the age of the car (looks like a 30 000km car inside), as you can see from the pics
and finally, the powerplant, please use caution when looking at the right hand side, turbo may cause eyes to pop and jaws to unhinge
For more pics see here QIK515 Photo Album
Ok so now that you've seen snippets of what the car looks like we can get down to business.
My asking price for the car is $27 500 FIRM. this includes the wheels plates yada yada. please do not make comments on price etc, as i have receipts totally over $43 000 spent on this car not including the purchase price, and it is a bargain for anyone in the market looking at getting a high performance motor vehicle (yes i shall reiterate again...280rwkw...no joke)
THERE will be absolutely NO test drives until a holding deposit is made, frankly because the car is a machine and i do not want people getting hurt (by people i also mean small children on the side of the road who may be sucked up by the massive TD06). I will drive the car before a deposit is made, and only if i deem the buyer serious enough to leave me a deposit afterwards.
Finally, to sum up, this car has been a well cared for, properly built street machine. I do not recommend it to people who commute in heavy city traffic (reason why i am selling), however for those who are able to truly enjoy this car, this purchase will represent the smartest economic move you will probably ever make (selling price is less than half the cost of a decent s15 + mods). It is not for the faint hearted and i will not let it go to a p plater (yes because it has....280rwkw).
I will also consider a trade for something which is more city traffic friendly. i want an s2000, however may consider other trades depending what you have. I am sure the first to see this car will buy it and i suggest you look around at other s15s before looking at this one so you have something to compare to.
If you have any questions, please dont hesitate to call or sms me on 0431 083 394. This car is a dream to drive (if not in city traffic) and has had alot of blood sweat and money put into it (the first two donated by the team at Croydon Racing Development, renouned SR20 specialists).
John 0431 083 394
How much power does this thing make lol
Nice car, fair price, although more than doubling the power from the factory and leaving suspension and tyres untouched does not constitute a properly built street car.
For those of you considering, 278rwkw is NOT scary in a daily driven S15 lol.....I put 230,000kms on my S15 making 259rwkw, drove it around 8 hours a day as a company car, in fact its still being raced around Sandown and Phillip Island.
Good luck and free bump
thanks lol. car makes 280rwkw.
suspension and tyres have been fixed now, and can be factored into the price. car currently sits on custom buddyclub p1s 18X9" rears on 265 pirelli rubber.
also suspension has been changed to zeal b6 coilovers with swift springs. car is basically complete. very fast car in immac condition
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
