hey bud have you got rb20 power steering rack and how much + postage townsville
nope sorry
hey mate, do you have the speaker grill that goes with that passenger side door trim? is so i'll take the trim
also do you have the trim that goes around the din/aircon control/ashtray etc?
nope sorry dont have grill i have the trim and bit around din aircon etc?
Mate, Ill take the indicator stalk, let me know how much for postage to Sydney and you account details, if you still have it, I'll put the funds into your account and send you my address.
Thanks,
Moray
will send u a pm asap
Got ECU?
no had microtech but sold that.
I HAVE MANY OTHER PARTS JUST PM ME IF U NEED SOMETHING
LOCATION - NORTH BRISBANE
ALSO HAVE RB20 ENGINE
DIFF
GEAR BOX
DRIVE TRAIN
DAMAGED SHELL
Python Alarm System Bought Brand new For $700 Will Sell For $200 - INSURANCE COMPANY COVERED.
GTS-T Bonnet - Slightly Preped for Paint $80
Steering Wheel - $20
Boot With Wing - $80
Dash Cluster - $50
Cluster Surround $30
Console Surround $20
Console Surround 2 - $20
FMIC unsure of size but i think its brand new - $80
Dash Complete Minus 2 vents... i know everyone is missing vents - $80
Drivers and Passenger Door Cards - $25 each or both for $40
Drivers and Passenger Side Gaurds - $100ea (high demand)
Front Seats $50 each or both for $80
Tail Lights - $80
Indicator Arm - ppl seem to break this alot. $45
Passenger Window Switch - this breaks alot for ppl but this one is fine. $40
Air Pod nfi - $20?
Rear Qaurter Windows Tinted hardcore - $150 each or both for $250 RARE
BN Rear Bar Fiberglass small crack - $80
CRACK
Rear Seats (2) - $60
Rear Windscreeen - $120
GTS-T Stock Suspension - $100
were r u located keen on the side skirts
  • 3 months later...
DIFF
GEAR BOX
DRIVE TRAIN
DAMAGED SHELL
Dash Cluster - $50
Tail Lights - $80
Air Pod nfi - $20?
CRACK
hey bud do you still have reverse lights and standard steering wheel?
    • Before starting any work, we attempted to adjust the tune. However even after adjusting it to certain extremes like completely stopping fuel, it had no effect. What fixed it was removing the Nistune Board and installing the original EPROM instead. This immediately fixed the issue. Everything should have been fine with the Nistune Board installation, so I am unsure why it has caused a problem. The soldered connector is also properly soldered. This worked when I first got the 550cc injectors, before cleaning, but that may have been a coincidence.  We ended up not installing the fuel pump hanger (at least for now). So currently running stock injectors, stock fuel pump, stock fuel pump hanger – Well everything stock except the exhaust. Now I have around €1400 in Nistune, Injectors, and Hanger collecting dust for the time being, perhaps I'll install them in the future. For now I'll enjoy the car as is 😁 Thanks a lot for all your assistance, I really appreciate all the help you have given me.
    • The turbo can’t be the issue. They’re proven to make much much power than you’re making. There is something in the setup that isn’t correct. - has the exhaust got any silly step downs? - what exhaust manifold?
    • Ok, just the way you wrote it made it look like you had the stagger the wrong way around
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
