I am hoping someone can help.. I am looking for a couple of holset units but cannot get anything without supplying a part number for the assembly.. I need an HX40 with 16cm T4 exhaust housing and preferably 7 blade compressor and 3" antisurge inlet. with V-band both ends. It woul also be better if it was external type wastegate. I then require the exact same unit with a 19cm housing.
If anyone is running either of these units, please can they give me some part numbers off them or can someone try and point me in the right direction to find them..
I am in the UK and even though these units are made here no one seems to know jack about them!
Thank you
Lee
https://www.sau.com.au/forums/topic/262571-holset-part-numbers-please/
http://www.dsmtuners.com/forums/turbo-syst...hread-only.html
BTW, I think all the 16cm HX40 housings are T3, not T4. Be careful--I've seen a few 6 blade HX40's around lately with 16cm housings, but the impeller was only 56mm, not the normal 60mm 6/7 blade.
I'm running a 60mm inducer'd 6 blade HX40 with a 19cm housing right now. I had to get the compressor/housing from one place and the 19cm exhaust housing from another turbo which is, I suspect, what you are doing now.
Good luck!
After doing some research Im ready to purchase a holset turbo. Im looking at hte HX35W and using the stock manifold. Does anyone have any experiance with this and is it just the 99-01 Dodge Cummins trucks that came equiped with this turbo?
I have searched on here for most of this but just need to clarify. Thanks for the help guys!
That's the best place to get them. Remember, they are much bigger physically than garrett GT series. I'm not saying it won't, but I'd be worried about it fitting down on the side of the motor and also of the compressor housing clearing the ex manifold. I've only dealt with a bottom mount HKS log manifold and top mount. For a couple hundred bucks though, I'd say it's worth a try :blush:
Thanks CJ.. I just found the DSM thread myself.. joined the forum to see if I can get a bit more info.. As far as my research tells me HX40's can come with T4 if 16cm or bigger.. Hard part is finding one with an external gate.. If you don't mind what is your engines spec and set-up and how's your holest performing for you?? I can't wait to get one! I am going for the 16cm to get my spool up nice and quick.. Am only going for 600bhp tops so shouldn't run out of steam before that. Wouldn't mind a 19cm for my rotary motor though!
Also the 7 blade is the preferred config although the 8 is very common. I have to say I have not seen many if any 6 blades when looking.. 99% of what's on offer is the 8 blade type. if I have to mix and match housings I will but ideally i'll get one ready to roll!
Cheers
Lee
hey mate, im putting a HX35 12cm on a s2 rb25det atm which will be going into a 260z, housing will hit the exhaust manifold so im getting a 20mm spacer made up and putting longer studs in the manifold. just bit of a heads up
cheers
jason
cheers
jason
Thanks alot I really appreciate the heads up! That 260z will be a beast
cheers
jason
I've seen a lot of the DSM guys use spacers successfully. Do you have a 7 blade or 8 blade HX35? The 7 blade is much better from what I head. You could always track down HX40 compressor and housing down the road and turn it into a hybrid like I had. That was probably my favorite turbo I've ever run.
They would be big enough for anything a HX35 could throw at it--higher than 25psi I'd think. I always lean towards bigger injectors though. More room to grow. Anybody who tells you that you'll get bad gas millage or shitty idle if you run big injectors on a lower hp car is an idiot. Anything small than 1000cc is good as long as they flow evenly and have good spray patterns. Ebay "venom" injectors are not good. 740cc Nismo's are awesome.
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
