  • Replies 335
Dyno Dynamics can run the car all they want, what is that going to prove...? It may or may not be within the limits of the software used.
Another car that got 339rwhp = 255rwkw on your dyno manages 111mph. On the dyno i use a 200rwkw gts-t will do the same TS.
Until we have a fixed form of measuring power that is used across the country, there is no point in quoting power figures.
Wolf plugins for Skylines is about 1 year old now and was basicly the first in the range. We have things like VLs etc on the market now and the list is growing fast. Sydneykid, please check your facts before posting as you are making a lot of false statements.
Yes but you arnt taking into account how bad I am at drag racing :P On the strip I never can get it right, look at my 60' times :) I need someone to be sitting in the car coaching me what to be doing and when and how, or I could let someone like rev210 or steve-sst, who know what they are doing, drive the car.
Need me to drive?
no worries rob! :P
I've actually been in Robs car, it has the power. Rob is a little too kind in shifting gears, something he can get help with I'm sure.
Rob how about giving us the 660 and 1000ft times and speeds, this will hopefully show the issue you had with the power drop.
Being a passanger in a car that's equipped with a Trust turbo like the TD06 may give you the impression that it's fast. Unless he was having a nap on the 1-2 change, a coffee on the 2-3 change and maybe a quickie on the 3-4 change, that 111mph is a good indicator of the power. :P
He didn't have one run and pack up, he had 5-6 runs, out of which the 111mph was the best. 13.88 is obviously is slow for the mph and can be improved on but i can't see anyone else improving on the mph by more than 1-2mph.
Incidentally, do you have a graph of your dyno run Rob...?
ROFL.......so you seriously think a car with a TD06 is going to produce similar power to the stock RB25 turbo?
If you are experienced in drag racing, you would know that drivers can make a massive difference in times, as dozens of other things will too.
If dyno dynamics say the dyno is reading accurately, what better comparison is there for power figures (when using shootout mode)? seriously.
Being a passanger in a car that's equipped with a Trust turbo like the TD06 may give you the impression that it's fast........
but you are saying that its not? I think you are completely wrong. Trust have been producing these turbos for years and sold thousands of them cos they are only as good as the stocker, but make the car feel faster????
Dyno Dynamic are forcing tough new Dyno procedures so they would not like to hear you comments. A mates car runs 11.4@112mph with 307rwhp on my dyno so a driver can have a big effect on 1/4 performance. Trust products are outstanding and been around for a long time so these comments are pointless.We will get Robs car down the 1/4 fast soon!Rob and Pauls cars are well planned cars built at a low cost and they have every right to be proud of their effort so stop grizzling and do better your self.
Yes this is true and the good thing is they acted fast and i came up clean plus GTSt Vspecs car was tested 5 days ago and after the dyno tests were done.. The new software is going to clean up the market,DD own the new procedures and will take it away from any shop tampering with it.If you think you get a fudged power run please report it even if its from me.I pushed hard to get this thru its just a pitty we can't clean up other brand dynos but they are a minority anyway.Look for Shootout accredited DD dynos Australia wide from now on to be sure you get the facts and then you can compare your car to any car featured in any mag world wide tested this way.
You are still comparing figures taken on different dynos. How do you know a GTS-T with a stock turbo gets 200rwkw on the dyno i use?
TD06-20G can support between 380-420hp at the engine depending on the trim. It is good to see that some can manage this just on 1 bar.
No one is looking at the times. His best mph of 111 out of 5-6 runs is a good indication of power unless he was on a leisurely drive.
Time will tell whether the 'shootout mode' is the new form of measuring power. From what i've seen so far, we are gonna get figures similar to the ones taken in US from their DynoJets.
If you are running the TD06 only on 1 bar, it'd be marginally faster than a well set-up stock turbo; however it would feel quite faster than before because of the way it spools up.
Steve-SST,
If you think the TD06 is an outstanding turbo good for you dude. I haven't knocked Pauls's or Rob's cars and efforts, if it came across that way i apologise. I've only been commenting on the power figures quoted cause it seems to be a bit high and at every where i look lately.
EDIT: And don't you worry, as soon as i get of my P's i will start to modify my car as well.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
