1993 R32 GTS-4 149,***kms
VIC Melbourne, South East Suburbs
Modifications
5 Speed R32 GTR Gearbox
Brand new Exedy Heavy Duty Cushion Button Clutch + Extreme Lightweight Flywheel
Full vertex Bodykit; Car Resprayed in Black
GTR Aluminium Bonnet
GTR Grille
R32 GTR Drivers seat, Passenger Seat And rear Seat
Wolf V500 ECU and Hand controller
Viper alarm
Apexi pen Turbo timer
Cadence Front and rear splits
4wd - 2wd Switch
Garrett GT2871r Turbo
Aluminium Radiator
Front mount intercooler
XForce Stainless Steel Exhaust
Whitline Swaybar
Koni Adjustable Springs
Adjustable Castor rods
Whiteline strutbrace
18" Gmax Rims with BF Goodrich Profiller tyres
Relocated oil filter
Bosch 040 Fuel Pump
Wolf V500, Tuned by Sabbadin, Made 220 all wheel kw's
PROS
Recently replaced; Fuel Filter, Oil filter, Engine Oil, Coolant, Gearbox oil and Plugs. Also has a brand new excedy HD cushion
button clutch
CONS
Has small dint on bonnet and also needs a Head unit.
Price and Payment Conditions:
$12700 With RWC, will sell without RWC (make an offer)
Pictures:
CONTACT DETAILS:
PM or Mob 0438067142
Edited by beRwick_GTRage
  • 2 months later...
  • 3 weeks later...
JUST PUT IN >>>
>new RDA slotted disc all round and QFM pads all round.
>new tyres all round.
>changed engine oil, oil filter, spark plugs and fuel filter.
Have receipts for everything!!
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
