The following parts are for sale they are for and off an R32 GTR
1. Complete New EXEDY push type single plate clutch heavy-duty rated upto 300KW @ wheels. $500
2. 2nd hand good condition EXEDY (push type) single plate clutch heavy duty good for at least a year. $250 ono
3. Two standard turbos with dump pipes. $300
4. Two AFMs Air Flow Meters in good working condition (Tested). $300/pair
5. Standard Cam gears. $50/pair
6. Complete Rear Tail Lights excellent condition. $200/pair
7. Flywheel. $150 ono
8. HICAS computer. $100 ono
9. 4WD Computer. $100 ono
10. R32 GTR Intercooler works perfect. $250
All Parts are Located In Sydney.
Postage can be arranged at your own cost.
https://www.sau.com.au/forums/topic/263241-r32-gtr-parts-located-in-sydney/
Complete engine Head in a very good condition the engine had low kms and the car was stock standard, and Yes it has everything including:
Rocket covers,
throttel body,
Plenum & Manifolds,
turbos (in perfect condition) with dump pipes,
Injectors with injector rail and wiring,
Cams and Cam gears
All in excellent working condition Ready to go on a block. $2000
Here are some pics of the clutches I also have HKS BOV for sale and a standard BOV complete with the pipes.
This is the New Clutch it has been modified so it's actually better than the standard and the standard is rated at 300KW @ the wheels, so this one will handle more than 300kw @ the wheels
I also have a Pair of 3inch Xtream Top filter (K&N) Air Pods to suit any car with alloy intake Pipes to Suit GTR afm's. Comes with the cleaning Kit.
High Flow Filter with Extreme Top
• Washable/Reusable
• 1,600,000km warranty from K&N
• Unleash the power within!
$300
The following parts are still for sale they are for and off an R32 GTR
I've discounted some Items
1. Complete RB26 Head in a very good condition the engine had low kms and the car was stock standard, and Yes it has everything including:
Rocket covers,
throttel body,
Plenum & Manifolds,
Cams and Cam gears
2. Complete New EXEDY push type single plate clutch heavy-duty rated upto 300KW @ wheels. $500 ono
3. 2nd hand good condition EXEDY (push type) single plate clutch heavy duty good for at least over a year. $250 ono
4. One AFM Air Flow Meter in good working condition (Tested). $170
5. HKS bov with pipe and all hoses required for fitting $350
6. A Pair of 3inch Xtream Top filter (K&N) Air Pods to suit any car with alloy intake Pipes to Suit GTR afm's. Comes with the cleaning Kit. $300
7. Standard Cam gears. $50/pair
8. Complete Rear Tail Lights excellent condition. $200/pair
9. Flywheel. $100
10. HICAS computer. $80
11. 4WD Computer. $80
12. R32 GTR Intercooler works perfect. $250
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
