5 stud - Skyline offset ,
Don't really care what they look like as long as they are in good nick, no scratches, balanced.
Sydney sellers - so I can look first.
Don't care what sort of tyres are on them, prefer none actually.
Not looking for super duper expensive ones.....
Cheers,
https://www.sau.com.au/forums/topic/26334-wtb-2-x-16-x-8-or-9-alloy-wheels/
Your going to need 17's to get something wider than 225's.
I've already looked into it (for track wheels) and even 16x8" will only give you 225's at the most (for semi-slicks if thats what your after). To get a 235-255 your going to need -atleast- a 17"
Hi Ben,
You are assuming that I want these for track wheels - I am looking for track wheels also - but I would go 18" or 19" for that purpose. (prolly new ones though)
These are for drags - you can get Nitto Nitto NT555R 245/50/16 which would fit nicely I think.
Cheers,
IMO:
* 16's with 225's (regardless of the tyre) is good for nothing but driving to work and back each day.
* Drags, a 16" would be ideal with -atleast- 245's on the rear (so the above mentioned 16" deep dish wheels would be ideal if you can get the rubber). I enquired about this at Gordon Levin Tyres and he basically shook his head at me when it came to find tyres to suit a 16x7-8. I didn't think of Nitto's so i guess it'll work.
* Track, a 17x7" would be bare minimum with a 17x8" being ideal so that some nice fat 255's can fit.
Over the next 3mths i'll be looking for some new 18x8's for my daily driven wheel/tyres and then some 17x8's for my track tyres. I'll be using the 17x7's for drags or possibly just using my standard r33 16x6's depending on rubber at the time.
Lemme know how you go Brendan coz it'll be interesting to see what combination you end up with.
A little off topic, but i recently sold my 17'' wheels and got some 16s, the reason being with 235 rwkw and more in the planning normal tyres FM901 at the time would spin up whenever i planted it, the only thing worth having is a semi slick tyre, now in a 17'' wheel these are well over $300, the 225/50/16 is $230, and i can garantee that my car with these tyres will out handle any 17/18 wheel with normal road tyres, the bigger the wheel in my opinion the worse the car handles(18''+) , the tyres are so tiny that they have no room to flex which they need to do.
No, but a 16'' wheel with a better tyre than that on a 17 wheels will handle better as there is more grip avaliable. I was refering to 35 series tyres in bigger wheels when handling suffferes.
Slightly off topic but thought i'd post it anyhow, this is an email i sent to TAKwheels.com.au regarding tyres sizes etc.
> Hi,
> In regards to:
> Product: Typhoon
> Brand: TAK
> Details: Silver
> Sizes: 17x7
> Off Set: 38
> Stud Patterns: 5/114.3
> I was wondering what the widest tyre is that could fit onto these rims? I
> currently have a 1995 R33 GTS-T which has stock 16x6" wheels which are
> running 225/50/16's.
> In looking on your website at the FAQ section I noticed that you only have
> 225's on 16x7.5" and above? I have seen 17x7's with 245/45/17 rubber on them
> without any problems.
> The reason I ask is because A) im a mechanical novice and B) I'm looking at
> purchasing these wheels purely for trackdays so the wider the tyre the better
> (want atleast 245+ for "Semi-Slick" track tyres). Not interested about daily
> driving on normal roads as these wheels+tyres would be fitted/removed on the
> day.
> Any help would be appreciated,
> thanks
> Ben.
In Reply:
Ben , Legally for road purposes a 225 tyre is maximum width on a 7 inch rim
accordimg to the australian tyre and wheel assimilation guide what you are
asking is for an 8.5 to 9 inch tyre to sqeeze its shoulders in to fit on a 7
inch rim this will negatively affect handling and steering the shoulders of a
tyre must sit square withh edges of rims as a minimum anyone who says
otherwise is misinformed also a 38 offset will narrow the wheel track of your
car by around 8 mm per side also negatively affecting handling on track street
is ok but track no way
regards
Michael
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
