  • Replies 85
I'm needing a passenger side wheel well liner (left guard liner). Does that come with the mounting hardware (clips and screws?) Also, the HKS piping, are we talking the intercooler piping? turbo side piping? Filters and elbows?
Parting out White R32 GTR. Currently have the front half as a half cut, and the rest is in parts
Fell off road on driver side RH Qtr panel hit bad, can cut off good left hand quarter panel .
Items listed below: See link for pics
Front cut includes 76000 km Motor/Box/Loom/ECU/brake master/Clutch master and slave/new twin plate clutch/ dumps/dash/turbos and just about everything you'll find in an engine bay, except cooler and piping. - $6000 or near offer. DEPOSIT TAKEN on FRONT CUT
Fuel pump $140
Fuel Door $40
Fuel tank $40 SOLD
Drivers Door (Trim+Cont) $50 SOLD
Passenger Door (complete) $150
Rear Reo Bar $50
Rear bumper $200
Rear Tail lights Pair $120 SOLD
Rear boot lid (wing + badges) $250 SOLD
Rear reverse lights Pair $30 SOLD
GTR Steering Wheels x2 $100ea SOLD and SOLD
Left Front Indicator $90 SOLD
Fog Lights (Pair) $75
Factory Cold air box $80 SOLD
GTR Grill $130 SOLD
Front Reo Bar $50 SOLD
Front Bumper (2x cracks) $200 SOLD
Twin Factory Dumps $5 SOLD
Blitz FMIC $250 SOLD
HKS Piping (RB26DETT) $150 SOLD
Side Skirts $150
Set of Side Pods $150
Right F guard (damaged) $250
Left F guard (perfect) $400
Pair Headlights $350
Left Front Guard Liner (perfect) $80
Rear GTR coilovers $150
Front Trust Coilovers $200
Aluminium Bonnet $300
Rear seats $10 SOLD
Glove box $10
Factory Gear Knob $2 SOLD
Momo gear knob $5 SOLD
Rear cradle $400 Deposit taken
Tailshaft $200 SOLD
Rear callipers, rotors $400 Deposit taken
Front callipers, rotors $500 SOLD
Rear sway bar $200 SOLD
Front sway bar $100
Front LCA (pair) $200
Front Upper Arms $100
Seat belts x4 $80 SOLD
R32 GTR Diff $900 Deposit taken
Radiator $175. SOLD
PICTURES : http://img291.imageshack.us/gal.php?g=dsc01036.jpg
Either PM me or call on 0403 071 294.
Located in The Gap, Brisbane. Would prefer pick-ups, but talk to me. Bulk buy discounts a specialty
Thanks
Radiator is SOLD.
Bonnet is the one in the pics, but very hard to get a pic showing damage, i will need someone who's OK at ally work to repair.
Bonnet closes and locks . Best to come and look at it ( Adelaide's a bit of a drive but!), sides postage/freight to SA will be a killer!
Hi mate.. intrested in the reo bar and the grille
does the grille still have the clips ??
and the reo bar looks a little twisted... wat's the condition ?
and can u post a better pic please
PM me.. thanks
PM me.. thanks
Sorry reo, front bar and grille all been sold
Dude that put deposit on front cut, box, diff cradle rear brakes and front knuckles has pulled out.
So
Front cut rb26dett motor complete/g/box/loom/ecu now back for sale $6000
Diff R32 gtr LSD with shafts ATTESSA and pumps $900
cradle with brake backing plates all arms $400
Rear brake rotors (almost new cond!) and calipers, $250
Front knuckles with hubs, ABS rings and sensors, cv shafts $250 the pair
Upper eccentric bushed adjustable front camber arms $150 pair
Front lower radius arms with eccentric adjustable bushes $150 pair
Lower control arms with very tight ball jionts, ( car had done 76000kms) $200 pair
do you happen to have rear backing plates for sale?
Yes but thay are all on the complete cradle
$400
Can supply rotors and calipers as well $250
does the gtr side skirts and side pods fit the gtst ??
If the GTST is around 1993 year model, and happens to be a two door, like a gtr, then yes they will fit.
They are some sort of flexible thick plastic that was fitted as standard to the r32 gtr model by Nissan.
If it's a four door, then they may need some trimming (easy with a small grinder like a dremel or 4"jobbie)
And yes, they are all still available.
I can do a better price if youy want both the full set of pods, and, the side skirts.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
