Hey guys,
Pulled apart a Wrecked White R32 GTR last weekend. Would like to sell of as much as i can. Currently have the front half as a half cut, and the rest is in parts. Am negotiable on most, so please ask.
Items listed below:
Front cut includes 76000 km Motor/Box/Loom/ECU/brake master/Clutch master and slave/new twin plate clutch/ dumps/dash/turbos and just about everything you'll find in an engine bay, except cooler and piping. - $6000 or near offer.
Fuel pump $140
Fuel Door $40
Fuel tank $40
Drivers Door (Trim+Cont) $50
Passenger Door (complete) $150
Rear Rio Bar $50
Rear bumper $200
Rear Tail lights Pair $120
Rear boot lid (wing + badges) $250
Rear reverse lights Pair $30
GTR Steering Wheels x2 $100ea
Left Front Indicator $90
Fog Lights (Pair) $75
Factory Cold air box $80
GTR Grill $130
Front Rio Bar $50
Front Bumper (2x cracks) $200
Twin Factory Dumps $5
Blitz FMIC $250
HKS Piping (RB26DETT) $150
Side Skirts $150
Set of Side Pods $150
Right F guard (damaged) $250
Left F guard (perfect) $400
Pair Headlights $350
Left Front Guard Liner (perfect) $80
Rear GTR coilovers $150
Front Trust Coilovers $200
Aluminium Bonnet $300
Rear seats SOLD
Glove box $10
Factory Gear Knob $2
Momo gear knob $5
Rear cradle $400
Tailshaft $200
Rear callipers, rotors $400
Front callipers, rotors $500
Rear sway bar $200
Front sway bar $100
Front LCA (pair) $200
Front Upper Arms $100
Seat belts x4 $80
R32 GTR Diff $900
Radiator $175.
PICTURES : http://img291.imageshack.us/gal.php?g=dsc01036.jpg
Either PM me or call on 0431657139.
I would like to move this stuff on.
Im located in The Gap, Brisbane. Would prefer pick-ups, but talk to me.
Thanks Guys
Jason
https://www.sau.com.au/forums/topic/263484-r32-gtr-stripped/
Hey mate, intrested in:
Steering wheel
FMIC
Factory Gear nob
Seat Belts (if original items)
I live in Mitchelton, brisbane, which is just around the corner. Send me a PM with your phone number ill arange a time to come out and have a look at what you have.
Regards
Ian
  • 3 weeks later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
