I am running one in my silvia, there pretty good quality for the price and much larger than standard. Mine bolted up perfect, just as good as a stock one, retains factory shroud and hoses as well which makes it simple. Took about 15 minutes to swap it in
Only thing I had to do was trim down the top radiator house about 1cm as the radiator is much thicker and sits closer to the engine
My friend just bought one for this R32 last week and it dropped straight in, no problems at all
Few drifters on NS.com using them, haven't heard anythig bad about them
Picture below so you can see the quality, I scored mine for $199 pick up so if your in Melb go and grab it and save on the $50 courier cost
https://www.sau.com.au/forums/topic/263619-asi-radiator/#findComment-4511148
great, thanks for that abu,
i didn't realise there the option of pick-up, i was going to buy off ebay and it stated 'online sales only' but i am in melbourne so i will definately be doing that. do you remember where you picked yours up from abu?
https://www.sau.com.au/forums/topic/263619-asi-radiator/#findComment-4511349
Yeah they don't advertise pick up on the EBAY ad but when I messaged them and requested for it they were happy for me to collect it. My friend also picked it up a few weeks back, there located in Mt Waverley
Try give them a call on 0433 657 560
Thanks
https://www.sau.com.au/forums/topic/263619-asi-radiator/#findComment-4511426
Yeh im using a ASI in my gtr its pretty good, i sorta regret it but because its the only china product i have on my car and it say's ASI over the the fin's where now i wish i said GREDDY or something lol. and it has ASI printed on the top of the radiator near the cap haha. But they do the job so i guess i wont be replacing it unless i have to it only cost $250.
https://www.sau.com.au/forums/topic/263619-asi-radiator/#findComment-4512202
Hi guys, I actually make radiators for a living (aluminium)
It's a simple technology, air passing over the fins, water passing through the tubes.
Chinese radiators dont look as good as hand made radiators by quality fabricators, but they do work.
Materials may not be as good, tank folding or tank welding may not be up to scratch and general fitment problems... You do pay for what you get.
I'm running a chinese radiator core with my own hand folded and welded tanks.. works good.
https://www.sau.com.au/forums/topic/263619-asi-radiator/#findComment-4514419
you earth them to avoid electrolisis which eats away at the alloy and can end up causing them to leak from all over the place usually ends up being 100's of pin hole leaks in the solder joints of the tubes to the header plates.
with alloy radiators it is reccomended that you run a glycol(sp) based coolant, i usually use the 50% tectaloy shit.. no water just 2 5 litre bottles is enough to fill the system and the overflow
but yeah... thats just me
doesnt hurt to throw in a bottle of redline waterwetter either more so for the engine side of things to help avoid airlocks in the system.
https://www.sau.com.au/forums/topic/263619-asi-radiator/#findComment-4515413
^^damn that's no good, i'm picking mine up tomorrow so i'll be sure to take my tape measure along too.
was also going to ask, are specific coolants needed for alloy radiators? or will any quality coolant do the job? Cheers!
You can use any coolant just don't mix and match brands/types etc as I read recently that if you mix different types of coolant it can cause corrosion
Have a read of this thread, it's pretty informative also goes through the procedure to check for electrolysis and a heap of other stuff: http://www.nissansilvia.com/forums/index.p...=denso+radiator
Definitely fits R32 GTST, seen it my self so no need to worry :P
https://www.sau.com.au/forums/topic/263619-asi-radiator/#findComment-4515480
spose this is one thing i missed, the main reason you dont mix coolants is due to its possible for there to be a chemical reaction and it can actually turn into a thick paste that blocks everything and well yeah.. is not good
https://www.sau.com.au/forums/topic/263619-asi-radiator/#findComment-4517167
arrived today, welds look dodgy and it has been sprayed with like spray on chrome or some shit?
i can clean alluminium radiators with mineral turps on the outside to get this paint off yeah? wanna see if it has big scratches or something and they are trying to hide it.
https://www.sau.com.au/forums/topic/263619-asi-radiator/#findComment-4532928
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
