  • Replies 130
Yea im good to meet at th BP, rlly was hoping for more than 3 of us tho.......atleast 5 and id be happy lol
Ill take a look at a map to see whats around for a destination, which way are u coming from john?
Edited by Joe_89
ok well im coming from albany creek area, my plan was to just cruise down beudesert road to beenleigh, left to waterford west to kingston, thru underwood, left at eight mile plains towards mansfield and right onto creek road to old cleveland road and thru th city, accross story bridge and then we could stop off somewhere? but thats just whats convinient for me/ best i could come up with lol. i dont know the roads too well, thats basically just following the most direct road without being on the highway. If anyone else has a better idea thats fine with me :)
Damnit! Scadtional is out so its just me and youkeen atm john and maybe ryan, hopefully more interest later, its not worth it with just 3 of us
Edited by Joe_89
ok well im coming from albany creek area, my plan was to just cruise down beudesert road to beenleigh, left to waterford west to kingston, thru underwood, left at eight mile plains towards mansfield and right onto creek road to old cleveland road and thru th city, accross story bridge and then we could stop off somewhere? but thats just whats convinient for me/ best i could come up with lol. i dont know the roads too well, thats basically just following the most direct road without being on the highway. If anyone else has a better idea thats fine with me :banana:
Joe...might be best to put this one on the back burner....too much fuel and travel for just two of us......
Sammy...sorry for spamming your thread..still keen for dyno day
maybe should create a new thread for it, if it is on.....
guys I apologise for the short notice, Ive been busy with work recently and havent had much time at all to post. But the date of the cruise as been pushed back as my car currently isnt driveable and I have found out :S my family has organised a suprise Bday party for myself tomorow. Good news is the EFI dyno is in but the exhaust fan is due to go in next week. So we have changed the date to the 20th of june.
Once again I apologise for the last moment thread.
~Sammy
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
