Drivein -fast N Furious 3.5or Whateva You Want To Call It
what night should we go? plz dont vote if you have no intensions of going
43 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 146
lol what are you taking ova here normsta :blink: respect my authoritie
nah all good, that could work but im a bit worried they may stop showing it after 2 weeks. my guess is theyll keep it running but you never can be too sure.
if anyone wants to try calling em to see if they are commiting to playing it 3 weeks straight feel free
cheers for the kick in the ass krishy :) sob
majority has spoken date will fri the 24th,
wear something pretty krisy and i might let you in back seat :P:)
anyways, in the event of an emergency and it is not showing cinema shall be where we heading. we will know by the monday of that week i believe. pretty sure thats how the webpage go's
bring some fuel if you feel the need to rev up your car with the pov spec lancers during the racing like last fn furious
http://www.youtube.com/watch?v=5tXyi3lSckA...feature=related
those of you that have to work plz give me ur boss's work number so i may call and abuse them
Edited by Inline 6
cheers for the kick in the ass krishy :P sob
<snip>
8212 2811, ask for the TGSM. :)
ill try to be there.
post whores atleast keep the important sh*t on the current page :P
fri the 24th
if you not there you.you..................prob pissed at me like those who are working :)
i have 1 that cant make it for fri, any others that want to abuse me?
I have a 21st the 17th and two Fridays off in a row and my boss will want to boot my teeth in,
Such a shame I won't be able to make it, Never been to a drive-in before either :)
wont know untill about the 21st, we are all clear im making an assumption it will be playing yes????
drive in lets you know whats playing and what time on about the tuesday of that week so if anyone wants to start checking it around there feel free to let us know.
id say 8.30 or 10.30 chances are, usually kids movie on before at 6.30pm
webpage for drivein
http://www.wallis.com.au/mainline.html
in the event of a unlikely disaster its not playing, ill be down for a cinema trip with who ever wants to go.
Edited by Inline 6
Sorry Dan i won't be able to make it mate
my flight from Mt Gambier doesnt get in till 8pm....so will most likely be missing out
could someone at least let me know what time you guys going...?
arrrrrrrrrrrr that be pirating you speak of, swervy mofo
fri 24
krisy tuffen up princess you disapoint me, you run the risk of falling down in the cool status rankings(possibly even below me)
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
