Hi all.
Just been directed to this site.. pretty mad..
Just curious.. i was lookin on other sites, and they had commodore group cruise on in da pics..
i got an R33 GTR, do you Krazy Kats hold any skyline cruises on the Gold Coast in Sufers?
If so, where n wen and all dat?
kool
I'll leave my number too if it helps- Thanx
ciao-
Joey.
0405710333
https://www.sau.com.au/forums/topic/26384-surfers-cruises/
Hey Joey,
Welcome aboard :D
looking for Cruises and events check here out http://www.skylinesaustralia.com/forums/fo...p?s=&forumid=37
You just missed a big cruise through Mt Nebo on Sunday, it was mad!
(you will have to keep up with the rest of the Gold Coast crew when on the cruises as we have a reputation to upkeep, shouldn't be hard in a GTR)
https://www.sau.com.au/forums/topic/26384-surfers-cruises/#findComment-558535
mainly people head to broadwater car park on saturday nights, just bewards copps have car busts there and inspect vechiles and under cover cops are everywhere, the esplande is on camera 24/7 so dont speed or do burn outs.
dont race on the m1, especailly with a cruise.
drag your friend in your own time and speeding is bad mmkay....
the laws up here are differnet also.
40+ over speed its $700 8 points and instant 6 month suspension.
speed caermas are NOT marked or hiding, like unmarked cars with speed caermas out the side, vans that sit on the side of roads and motorbike coppers crouched behind a roadworks sign.
but the main places are easy to find if you just cruise around followin people for a night, they show you everywhere.
and uhf channel is 16-20.
safe driving and hope to be cruising soon :D
https://www.sau.com.au/forums/topic/26384-surfers-cruises/#findComment-558586
surfers cruising is more posing than anything else,
organising a cruise through surfers is pretty much a waste of time. traffic lights break up groups and it becomes a pain in the ass.
cruises and events are commonly organised and details are posted in these forums (events section and otherwise)
if your bored of a sunday do what everyone else does, lap the esplinade, personally im sick of it, too many ****sticks and wannabes get down there and hang shit on people. if you dont have a gtr, big wheels or wild paint then u dont count it seems.
saturday nights if your bored is the bwcp, however esplinade is also happining then as well if you feel the need to show off to the pedestrians.
basicly sunday and saturday is a cop fest, u will be pulled over if you fart in the wrong direction.
https://www.sau.com.au/forums/topic/26384-surfers-cruises/#findComment-558627
and watch when changing gears in the wet, i changed from first to second and got done for "drive a vehicle in way that makes unnecessary noise" yes the car did move a bit sideways, but thats because i realsed the clutch a bit too fast :D
$240 and lucky not to have 3 points taken.(which is the usual fine)
https://www.sau.com.au/forums/topic/26384-surfers-cruises/#findComment-558648
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
