  • Replies 98
Posted Images
This picture shits me, i took a few of them, but none made me happy with the result...
how do i make it look better,,?? like crisper and sharper.... should i be using photoshop or doing it before pressing the button..
any tips would be great guys
Try increasing your f-stop a couple of steps and give it another shot. Also, shoot in RAW mode, then convert in Photoshop with CameraRAW later, will be much more crisp.
Here's one from the SAU display at the F1 on the weekend:
The image looks alright to me tho..
Isolate the subject. You got distracting items in the back. Your main focus is on that glass right? Or did you want the other glasses to be seen too?
Make yourself a small light box ;)
This one took me 2mins to make:
Put your glass in there.. shine some lights from both sides of the box.. Choose whatever background you want and have some fun.. Its like a mini studio :P
oh the image below is just zoomed out to show how the box looks like etc..
What camera you use?
If its just a digi cam then step back a tad and perhaps use that macro function.
If you do have a slr you will have a lot more flexibility in terms of taking the image and processing it after on the computer.
Also remember when you resize an image the sharpness decreases.
Edited by siddr20
Make yourself a small light box :)
Put your glass in there.. shine some lights from both sides of the box.. Choose whatever background you want and have some fun.. Its like a mini studio :(
It's a point and shoot.
Agree with siddr20, find a better backdrop and it will look much better. Picture quality is pretty good though.
Thats a weird one uh.. Maybe a bit of flare?? Dirty lens?
Definately not flare, and I thought it maybe a dirty lens but I cleaned it and it was still there, put on a diff lens and its gone.
I did noticed that when I took it off and then put it back on the green spots moved.. I'm puzzled
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
