  • Replies 250
Don't know if there is a limit on how many cars, wasn't mentioned last time. Either way if we get there 8:30 we should be fine for spots.
Anyone else up for meeting at Kart Mania (or laser force or whatever) before heading to Mallala?
usually meet at caltex on the left, on port wakefield rd. just after bp.
Yep vote 1 for caltex on port wakefiled road just as u pass the BP on the right
its near my house so let me know what time boys and i am keen to meet up
I will be coming out to take photos, if anyone is interested in having some photos taken of your car let me know so i can make sure to target the car as it goes around....
Havn't been up since January because i have been busy, here are my photos from Jan if people want to get an idea of what i do.
http://aussieexotics.com/drivers/thumbnails-361.html
I will definitely be there, the question is on the track or not but I am not deciding now, I will do a brake bleed and new pads + change a gasket, if I can get all that done by then (should be able to) then I'm on the track like a mofo. If not I will at least be there to take photos and see who gets kicked out for drifting ;)
Scandy you should come, they don't allow Silvias on the track so you can just watch :P
I know what it is, Silvia = 200sx. 300zx = fairlady.
Same cars people. Next you will be saying a Holden Apollo is not a Toyota Camry. :P
The badge does not change the car
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
