310 wide
710 high
18" wheel
so they are damn big. off a porsche cup car or something?
18" wheel is 450mm so tyre is (710-450)/2 per side =130mm. 130/310 gives .40 aspect ratio. So 310/40/18 is about right.
Standard on a gtr was 225/50/17 which is 660mm high.
Depends, if it in inches it 31 inches tall and 71 inch circumfrence. Most companies with will give you height and rolling diameter as the affects diff gearing.
dayum...ok well whats the widest i could go on r34 gtt?
worry about buying a decent tyre first, better off with a better thinner tyre, than a worse wider tyre. understanding im judging a book by its cover, but going by ur avatar ur car doesnt look like it needs anything over 300mm wide.
300mm wide is what in regular size?
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
