Hey guys,
New to the club but here is my history.
Bought R32 GTR in 2006, came with:
HKS 2530s, Seller didnt know and i didnt notice til 3 months later lol
Upgraded injectors
Twin plate ATS clutch
Trust front mount
ARC airbox.
HKS Boost controller
HKS Turbo Timer
Since then have added:
80mm AFM with pod filters
Apexi Power FC with hand controller
Aluminium radiator
Oil cooler and filter relocation kit
Relocated battery to back floor.( Dont have friends that are game enough to get in the car with me lol)
Alcon 4 piston front brakes
New head with Type B cams and stronger valve springs
HICAS locked up, and all plumbing etc removed
A/C removed and all pipework
N1 Water pump
Have had a run of bad luck though, Water pump died and cooked head, new head installed and 3 weeks later threw rod out side of block at the hairpin at Symmons.
Bought long motor to put in, decided to do a monstor build on that motor, ran out of time before the start of my car club season so purchased a complete but wrote off car, put the motor in with my brand new head and fully rebuilt turbos only to find a had an idle problem. Spent some time chasing that problem and now the oil pressure has dropped. Havent even pulled the motor out as im that annoyed lol.
Will continue building my monstor motor and will put that in bout xmas time, fingers crossed.
So yeah, atm i am twiddling my thumbs and getting some other projects out of the way, finishing my car trailers( Which i dont need anymore as i dont have a car to
tow around lol and gathering up some money to finish off the new motor.
So far for the new motor i have:
Chemically cleaned and bored block 87mm
Venolia pistons
Eagle rods with ARP Bolts
ARP main stud kit
ARP head stud kit
Sump baffle( Am thinking bout getting an enlarged sump though, something around 8 litres or so)
ACL bearings
Brand new 33 crank
Rebuilt head with stainless valves and Type B cams
Ross Tuffbond balancer
Adjustable Cam gears
Only need to get a bigger oil pump and get my turbos checked and get the whole lot balanced and screw the thing together and im laughing.
Anyways, will keep you all posted
Pointa
First motor= 11.84 1/4mile, 328 RWKW, 1min 3 at symmons
Guesty, drive harder lol
https://www.sau.com.au/forums/topic/265163-whats-been-happeing/
Hey Michael, Damo here with the white gtr. good to see you took my advice anfd joined up, lot of info here and advice if you look, from seasoned drivers and builders. hope for ure sake you get things sorted with the gtr, see ya round. p.s mods should move this into the Tas introductions area for you.
Edited by madaz R33
Yeah cheers mate, still trying to work out how to put posts and stuff in the areas i want lol, will work it out eventually i spose
Dont let this happen to you, buy a sump baffle at the least, i shouldve built a decent motor the first time
Good to see you got two real cars
The 32 and a two door Torana.
Pity its not a Hatch is all... :)
You heading down to the kart track in Smithton this weekend for a look??
Taking my GTR out for its maiden Australian track day. (The harness mounts etc kinda give away that it was raced in Japan ;) )
Alex with the grey gtr on 20s here, whos not game enough to come for a drive haha!?
HAHAHAHAHA, very funny mate, just you wait til i have it back on the road, i will be game then, especially if we put a decent wager on it ha ha ha
Pity its not a Hatch is all... :P
Taking my GTR out for its maiden Australian track day. (The harness mounts etc kinda give away that it was raced in Japan :cool: )
Yeah got 2 real cars, the 2 door torana is my baby, the 32 is just my bitch hahaha.
There is something a bit sentimental about 2 door LJ's, i think its got something to do with them beating GT falcons at bathurst, call them the underdog if you like :P
What day is the kart track day? Wouldnt mind going for a look but i got a fair bit on my plate atm, if i do go it will only be for a few hours,
  • 3 weeks later...
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
