i got my car serviced a few months back and i asked for platinum spark plugs and i have just had a look in there today and took a spark plug out and they are cheap normal spark plugs.
i asked for platinum cause that is what people on here recommended and im pissed off i had to pay for the cheap ones at the price for platinum's and the mech is shut for Easter so i cant abuse him.
can this screw my r33 gtst up? do they have to be platinum's?
i will never trust a mech again and i wont be lazy and do it myself next time.
https://www.sau.com.au/forums/topic/265165-spark-plugs-average-or-platinum/
without getting into the topic of what is better, normal coppers vs iridiums. i wouldn't be worried that he only used normal ones, it wont stuff your engine up. a lot of people only run normal coppers.
the only thing i would be worried about if i was you is the fact that you paid for iridiums and standard coppers were used! there is a fair bit of price difference between the two.
thats a surprise. I would have expected "people on here" to suggest you not waste your money on platinums and just get coppers unless you don't like servicing your car yourself..then i can understand why you chose platinums.
wont do any damage and no they dont have to be platinums but if you paid for plats then you should get plats
well the one thats more expensive and better than Platinum plugs are the Iridium tip ones...
supposedly from the manufacture...The result are spark plugs that require less voltage to spark, burns fuel more efficiently, sparks at leaner air/fuel mixtures, and delivers higher horsepower and better gas mileage.
you would say all that too if you were trying to make money out of spark plugs wouldnt you?
NGK has released a new one called IRIDIUM IX...evoloution spark plug....
finest spark plugs in the world apparently...
but at the end of the day, some people just want to go all out on thier car... best oil, best fuel, best plugs, best brake fluid etc...
it may not be all that necessary.
i wouldnt really bother that much, i usually rid them every 40,000km anyway
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
