Hey guys.
Have had this issue with my 33 for a while now and am going to be hopefully fixing it very soon once my new brakes go in. Just want to basically know if anyone has had this problem or knows what it is.
Best example is if im on the free way, i can literally make the car change lanes either way by just using the brake or throttle. When i brake, the car leans to the right while the steering wheels slightly leans to the left.. :laugh:
If i accelerate the exact thing happens in the opposite direction (left).
If i am driving straight at a steady speed (not braking or accelerating the car is pretty much going straight.
Could this simply just be the need of a wheel alighnment or something loose/worn that needs replacing?
I did install aluminium rear cradle bushes & a hicas lock bar 2 years ago before the car came off the road and i cant remember whether i did a wheel alighnment on the car afterwards or not...
Appreciate your help
Edited by Dean_HR31
https://www.sau.com.au/forums/topic/265176-help-with-my-steering-problem/
yeah start with a wheel alignment. that will tell you the basic stuff is OK (or not).
generally a car that pulls one side under brakes has stuck pistons in the brake on the opposite side - so you might need to overhaul the front calipers too.
yeah think thats a good idea...
Also can somebody tell me if a wheel alighnment would be affected in any way if i was to change my rotors and brake pads all round after completing a wheel alighnment???
you never aligned it? lol
when i installed my hicas bar i had to practically crabwalk my car to the suspension joint for an alignment. you'll definately be out...
take your front bar off before you go in too dude.... the 400r is way too low for like 99% of alignment machines.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
