Xf Throttlebody & Longer Throttle Cable ......
Hey guys...
Im currently in the process of installing a custom front facing high volume plenum on my RB25DET and already have a XF throttlebody chromed and rebuilt with the cable action modified to a 'pull-back' manner.
Now, how do I go about with the TPS as the XF throttlebody open/rotates in opposite directions to the RB25DET unit ??? Ive had people say wire up the original FORD unit that came with the XF tb, other people suggesting using a RB30 TPS..... I know this is a common conversion on RB25 motors pushing up to 350+rwkw so HELP GUYS !!!!
By the way, Im running a PowerFC if that'll help any....
Also, where in Sydney can I get a longer throttle cable made up for relocating the throttlebody to the front of the motor ?
Any help is appreciated !!
Edited by smok74
in regards to the throttle cable give lincorp automotive at ryde a call 8844 4400 and speak to the guys in the nissan section and ask for a Z32 (300zx) throttle cable, their address is
3-5 Grand Ave
Camellia,
Sydney NSW 2142
they're who i went to when i did my plenum change....
And if they dont have any in stock give just jap a call down in kirawee im fairly certain they have some in stock.... their address is
101 Bath Road, Kirrawee
Sydney - NSW
2232
PH. 95450532
hope that helps dude
DID SOME RESEARCH.....
I think the standard XF TPS that came with the XF throttlebody may be used......
FORD XF TPS PINOUT :
GREEN - SIGNAL
ORANGE - 5V
BLACK - EARTH
They both operate at 5 volts so why cant the ford unit be wired into the standard RB25DET harness ?
I know the series 1 and series 2 RB25DET TPS are different as the series 1 has one plug and the series 2 has two plugs -
REFER TO:
http://forums.nicoclub.com/zerothread/283142
This forum listing explains how a 3-wire 5 volt TPS can be wired into the series 2 RB25DET (2-plug) harness
I'm in the process of hooking everything up and see what happens.... worse comes to worst, I've got a brand new generic 80mm throttlebody sitting here that I can use the standard RB25DET TPS with......
