hi
i have a friend who have a performance garage and want to someone from australia who can program a motec
the garage is in United Arab Emirates which some people thinks its dubai which is not while dubai is a city of the emirates
the salery is 10,000 dirhams a month which i cant calculate it becuse of the changes of the currency day by day ( there are not tax in UAE )
and an apartment
who wants to work plz pm me and ill send u more details
im in vic
sorry for posting the ad here cuz i didnt know were i can post it and im new in this fourm
https://www.sau.com.au/forums/topic/265209-programing-a-motec/
at current conversion rates thats about $3700 a month, or $900 a week cash. most tuners will charge ~$150 an HOUR to tune.... i dont think your gonna find a tuner, let alone one specialising in motec thats gonna pack up and leave everything in this country for $900 a week.
however, i think that guy from Chasers, (Scott mighta been his name?) has gone over that way before to tune cars, i dont know if he'd make it permanent but its a starting point i suppose?
ya but there are no tax there and everything is cheap and he's not gonna pay on the appartment and maby there are bounses
there was a garage came from australia and opened in dubai the garage name was sub zero and there salery is the same or maby less
then what salery would u want us to put ??????????
look i said this is the salry but there are bounses and in every company and every were the salery is not much put the bounses which push the salery up
the guy will get a salery + an appartement + a car
its only for programing a motec
the salery will increase year after year
what could i do more
this is the deal u want to work ur welcome u dont then plz write something good
btw when i say there are no tax on salery i mean there are no tax in the whole country
the only country in the world which there are no tax
everything is cheap compare to here
for example a second hand ferrari 360 2001 is for 80,000 dollers
bmw X5 v8 full option with sports kit 0km is about 100,000 dollers
resturants are cheap , hotels , everything is cheap it means 10,000 dirhams is good for living in UAE
i'm aware of tax situation, and how cheap cars are. dont take what i say as a personal attack, i just think maybe your looking in the wrong place for a tuner.... is there really no tuners over there? why not find someone who can learn how to tune? or find someone over there, bring them over here for a bit to learn how to tune?
I think its more than reasonable salary.
A tuner here has to pay for the maintenance of a dyno, rent of the workshop and if they have anyone else working for them then the salary of their staff. This is probably why some workshops charge a lot to have your car tuned as they factor these costs into the price.
I think you will find that most WORKSHOPS will charge $150 per hour.
I hope you find someone for the job, it would be a good experience!
yeah obviously i wasnt allowing for all the outgoings of having a dyno/shop, but i still think after all the outgoings, you'd end up with more than 900 a week in your pocket (depending on the flow of work).
R31nismoid, re: salary, it isnt too bad, could be better, but how much would it have to be for you to pack up and leave everything behind to go work over there?
PS: i may be a little biased, coz i've heard some seedy shit about dubai
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
