i have just bought an r32 4 door rb20 turbo which is my first turbo it has
*bilstein front shocks
*koni rears
*runs standard boost(at the moment)
*everything on the motor is stock except GTR injectors and GTR radiator stock exhaust runs on 18 inch rims....the rims are stamped in japanese writing so i dont know wat kind of rims they are. Could any one tell me how many kwts my car ruffly has now, and can anyone tell me some good cheap and easy mods to get me started i am currently in the process of getting it dyno tuned. I just wanna do a couple of things first then get it tuned just some ideas would be great and any heads up to cruises would be even better cheers
https://www.sau.com.au/forums/topic/265253-can-anyone-help/
Hey man
You could get a pod filter so it will let you hear the turbo and induction noise better
Then buy a 3inch exhaust to get a nice beat and let the car have more flow
Also put an intercooler in and then should be able to do a nice tune and make a pretty nice figure on the dyno.
Welcome to the forum, Niran
https://www.sau.com.au/forums/topic/265253-can-anyone-help/#findComment-4542007
thanks champ i got a pod filter and you can really hear the induction noise thanks for that...3 inch exhaust aye i will look into them now if i get a 3 inch exhaust will that mean i need i turbo cannon?i like the stock look that i have going now destroyed a mx5 turbo yesterday in sydney he thought i was stock ha ha...thank you again for the pod filter idea it sounds unreal cheers....have you goy any ideas for an intercooler?? not too keen on ebay jobs thanks
https://www.sau.com.au/forums/topic/265253-can-anyone-help/#findComment-4548691
DONOT put a pod filter on without making/buying a cover for it, it will only suck hot air and you will lose power. Keep your standard air box and just put a quality filter in. Cold air induction if it hasn't got it already.
First make sure your brakes are good.(discs OK, new quality pads, bleed)
Full Service
Suspension(sway bars are the best cheap performance upgrade in my opinion)
Turbo back zorst with high flow cat, (biggest cat you can fit, keep the DB legalish to keep the Police happy and dont use a cannon as they are gay and will attract unwanted attention)
Most parts can be found at wreckers or import yards.
You may even find a good electronic boost controller, if not a cheap bleed valve will do.
FMIC (paint it matt black to avoid being a defect magnet)
Take it in for a tune.
Lots of good websites out there, check this one out for some nice cheap/free mods.
Most importantly, dont drive like a idiot on the street.
http://autospeed.com/S_10/cms/section.html
https://www.sau.com.au/forums/topic/265253-can-anyone-help/#findComment-4549578
Hey mate thanks for the heads up im getting a custom air box made now just waiting for finishing touches...i am booked in for a dyno tune on saturday just wanna keep everyting stock and quite just keep it tidy and well maintained for now its fast enough.....the track day link wont work cheers
https://www.sau.com.au/forums/topic/265253-can-anyone-help/#findComment-4571155
hay champ thanks aye im planning on going to import wreckers in sydney on the weekend just to have a look around and see wat parts and accesories that they have......at the moment i really am just enjoying boosting around......could you tell me if a turbo stamped AR50 is it stock? cheers
https://www.sau.com.au/forums/topic/265253-can-anyone-help/#findComment-4581914
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
