I have been having trouble again with the front headlights. The switch has been rebuilt 3 times and looks like both are stuffed . This I can remove and install myself .
I have been told that they are $300 new from Nissan.
If you know where I can get one for less please let me know.
Does ? anyone know a Good auto Electrician though because a fuse has blown and I'm guesing which one.
Plus I think there is more than one thing wrong there.
Also to do that aircon fix youve mentioned on here.
Would ask that the sparky is on the northen side thank you.
There is no listing above for sparkys ? ^^^
https://www.sau.com.au/forums/topic/265360-auto-electrician/
Clisby auto electrician on Main North road (near Main North Nissan) did pretty good work on my car.
I reckon they'd easily be able to fix the aircon esp if you could print out the howto guide and give it to them (I did that fix myself)
Give em a go
-D
I took my 32 to Gawler Auto Electrics at Gawler Belt. They tried to get my a/c going but it turns out the clutch on the compessor is screwed. Seemed professional gave me a full report and everything. Reasonable price. I would go back.
cant remember the dudes name...
ABM securitiy i think its called theres a thread on here by kidafa... he did my alarm for me, took him alot lot longer than expected yet didnt change the price, fixed my window and power window switches at the same time for free! wouldnt ever use any one eles... he usualy will c u with in a few days.
hey man,
what have you done to fix your headlights?
on my other skyline the actual plug for the headlight was moldy and shot. there was corrosion into the wire and was giving it a faulty voltage in turn i was
buying a new set of globes every 2 weeks lol.
G E auto elec para hills is awesome, he helped me find why my car was mysteriously cutting out :down: speak to george :thumbsup:
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
