So I fell in love with a set of SSR Type C RS in Gunmetal Grey. I heard that Jeff at C-RED does SSRs, but I rang him this morning and he said that what he's got in stock is the last of it as he's no longer importing them. Anyone else know of anywhere in perth I can find 18x8 SSRs?
A close second would be some Enkei RP03s but they're rare as hen's teeth as well, I can't seem to find them anywhere - I keep getting told there aren't any in Australia at the moment. What to do, what to do?
Anyone have any suggestions? I'm after a lightweight wheel that's more drift than bling in a 5 or 6 spoke... and thanks to some dodgy wheel alignment a few months back (now fixed) I'm nearly driving on steel so it's getting kind of urgent :D
https://www.sau.com.au/forums/topic/265405-c-red-no-longer-stocking-ssr-rims/
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
