1997 200sx S14a - Red with Pearl Swirl
5 Speed Manual.
Regoed till April 2010
Serviced every 5000 K's.
Blacktop SR20DET VVT - 220,xxxkms (Original motor - Has good compression when tested recently 140 all 4)
3" Dump and front pipe
HKS Catback
Trust Front mount Intercooler Kit
Apexi Power Air Intake
Walbro 255 Fuel Pump
9 Puck Clutch 2200lb Pressure Plate
Yoshio Factory Copper Radiator
Defi Boost Gauge in Pillar Pod w/ Defi Controller.
Turbosmart Bleed Valve (Running .9 bar)
Nismo Leather gear knob.
Genuine R32 GTR Driver and Passenger Seats
Aftermarket HKB Boss kit with King Dished Steering wheel
HSD Adjustable Dampening Coilovers (F:8kg/R:6kg)
D-Project Rear Subframe C Collar Bushes
D-Project Rear Camber arms
D-Project Rear Toe Arms
Genuine R33 GTR 17x9 Wheels with 215/45/R17
Genuine Luxury Front Lip
Genuine Luxury Side skirts
Vertex Side skirts (not fitted)
Vertex Rear Bumper (not fitted)
Genuine K's Model Aero GT wing (not fitted)
Misc.
Alarm and Central remote locking
Kenwood MP3 Deck w/ JVC Amp (4chan) running Splits
Genuine Nissan Silvia floor mats.
I drive it every day to work (40km) and have had no problems at all, never missed a beat.
$15,000 ono
I'll be taking some pictures later this afternoon. If you wish to inspect or call my number is 0438 010 323. PM's may or may not be replied to. It is best to call.
https://www.sau.com.au/forums/topic/265874-wa-1997-red-s14a-200sx/
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
