Item: 1992 r32 gtr
burpengary
Item Condition:
very good, motor has less the 5000km on it. paint could do with a buff, but pretty good. no dints at all.
134xxx genuine km's
Reason for Selling:
other projects
Price and Payment Conditions:
it's really an expression of interest, however i need a price so 40,000. make me an offer.
i may be interested in swaps with cash my way, either for a motor bike (sports or cruiser, must be learner legal) or another jap car, no fwd though.
Extra Info:
bbs lm's 17x9 2 piece wheels.
255 federal tires (heaps of tread)
mod plated cusco half cage
greddy oil and water temp guages in a pillar pod
momo steering wheel
4wd/2wd switch under dash
aftermarket dump pipes into hks front pipes
3 inch exhaust 1 muffler, ending in a cannon
2860-5 turbo's (34 gtr n1's)
hks cams 264-272
hks adj cam gears
head recently rebuilt all perfect
some port work done
greedy hard pipe kit
oil cooler+relocation kit
king springs
koni adjustable shocks
all new bushes
turbosmart fuel regulater
nismo 600cc injectors
forged cp pistons
20 thou bore
spool forged rods
all new bearings
arb head stud kit
high octane large baffled sump and longer oil pickup. takes 8ltr of oil now
oil drain in the back of the head
tomei oil restricter in the head
nismo supercoppermix pro twin plate clutch
splitfire coil packs
wolf v500 ecu
removed afms
2x apexi pods
there's more but i can remember and i don't hace the list handy
will put up a dyno sheet when i can.
car pull 465hp at the wheels (346kw) on 19psi
with a larger exhuast and some non standard exhaust manifolds it would easily and safely pull over 500.
could pull more but didn't want to push the motor too much while it's fresh
Contact Details:
just pm me here or on 0458244605
these picks are the old ones, so ignore the plates. only a couple small changes on the engine bay. and new dyno sheet, don't have a photo yet though
https://www.sau.com.au/forums/topic/265885-r32-gtr-built-motor/
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
