hi guys,
im not sure if i need to run low or high impedence injectors for my gtr. has a power fc & the resistor pack is still in the car so im pretty sure its low impedence.
if i take out the resistor pack & run high impedence is there any advantage in doing this?
what style of plug does the gtr have, is it what they call a denso plug?
https://www.sau.com.au/forums/topic/265886-injectors-for-gtr/
Why don't you find a workshop or tuner your happy with, Pay them for an hour of their time and sort out exactly what you do and don't need for this engine your building??
Not trying to be rude but it would save you alot of headaches if you ask the one person who will ultimately make or break the rebuild your doing.
Just food for thought
Agreed.
It seems 'Marko' and 'im late' are the main players getting a rebuild or upgrading their shit at the moment...a new thread for each question and each different component on their engines.
Getting pretty draining.
i apologise in advance as i just found out that the sales rep im dealing with has nfi
the guy couldnt point me in the right direction with impedence or plug... i finally found what im looking for on google
hopefully this thread might help someone else who is searching for the same answer, gtr runs a bosch plug!
pls ignore this thread :-)
high imp in your size requirement would be rediculous. low imp are much better. who the hell runs 800cc high imp injectors ?
Umm every 800cc SARD equipped GTR, same as 700cc SARD (and every other GTR replacement injector on the damn market in 700-1000cc)
Your point exactly would be...?
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
