first of all, are these 2 tyres in a similar price bracket? i'm guessing they are arong the same range
i have a price for the 595's, wondering what kind of cash you're up for for 17" 235/215 in the toyo's
so which one is the better performing tyre?
thanks
https://www.sau.com.au/forums/topic/266293-toyo-proxes-4-vs-federal-595ss/
I have been happy with the preformance of two sets of federal 595's in 245/45/17 however am now switching to Kuhmo ku36's as there is a negligible price difference between them. The kuhmos will not last anywhere near as long however, so if the car was a pure street car I think 595's are good for their price.
I have 225x17 on the front with Proxy 4's and 255 on the back with federal 595's. Hard to say how good they are as need the same tyre all round to give a good opinion. So I'll try anyway.
The Proxy's are very good over the Hankook K104's I had previously, in fact, there is no comparison. The Hankooks would understeer badly in the rain and dry unless really warmed up.
The 595's on the back are better than the Hankooks for grip in a straight line but MUCH better around corners. As an aside, have you priced the T1R Toyo's ? They are a very good tyre for the money. Though the 595's are the best for value.
Edited by skylinecouple
yeah thanks for the info guys, i ended up ringing bridgestone out of curiousity for some adrenalins, got them for $225 each on special
they are better than both of these tyres so i'll take the opportunity.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
