Will this work guys, my car will be going to just jap in a couple of weeks as it is almost on the dreaded 100, 000KM's :). They are charging the best price for a service including the water pump which most places mentioned at an extra cost.
I was going to have them take mine off an fit the High flowed R33 items they exchange with cash. the only thing I want to know is, will it drive almost like it does now? or will it run like a dog (ie rich, spluttering and not boosting). I am going to get a power FC after xmas with a blitz boost controller. I just wanted to know will it drive like it does now, maybe better or will it be worse and the computer needs to be done straight away.
cheers guys
mark
100,000kms or thereabouts is when you should change the timing belt, water pump, spark plugs, oils, fluids and hoses..
some things like diff oil, clutch fluid, brake fluid radiator hoses aer forgoten sometimes during your 5000km services that you might do.
so this service tends to be more expensiev than others..
My one (at 93,000kms) cost me $1800. but I also changed the radiator, clutch fan, upper and lower, front and rear bushes (that was the most expensive part)..
this is on top of all the other things I mentioned which I also did at that service.
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
