Don't they get complied for the Aus market on import? Like, things added to them to meet Australian standards? So do they even have the same seat belts on Japan or wherever as they do here, or as they changed as well? Cause that might explain why some are 2+2 and others are 5.
https://www.sau.com.au/forums/topic/26644-r33-4seats-or-5/#findComment-563493
the guys with 2+2s, what year are your 33s?
mine only has 4 seat belts. i think they are really only supposed to be 4 seat cars as the middle in the back seat isnt really a seat more a divider for both sides. Actually I'm not 100% sure check the underneath for thread holes etc..
mine is a 93
https://www.sau.com.au/forums/topic/26644-r33-4seats-or-5/#findComment-563629
Man I always though that all Skylines R33 is only 4 seater?!?!
Didn't know some of you guys have 3 seat belts at the back!
I only got 2 seat belts and it is a 94 model. That's weird. So you can fit another seat belt in the middle if you want to??
Dude that's pretty cool, more girls at the back hehe :)
https://www.sau.com.au/forums/topic/26644-r33-4seats-or-5/#findComment-564490
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
