Traffic Hazard (avoid Whites Road, Salisbury)
Tommmo
 Share
Just a warning to all those that might be driving through the area.... SLOW down!
Or avoid the road all together if your car is lowered or have low front bar.
There's a "Hazard Ahead" sign, but no indication to slow down.
I was in my Chaser, travelling along at 50, behind another vehicle and didn't notice the massive slabs (3 of them, 10m between each one) of road which the council has cut out and filled in with dirt and with todays rain...all the dirt has eroded. Each ditch is around 8-10cm deep!
I hit the first one at 50km, by the time I realised what happened and reacted, I was going through the second one around 40km.
I pulled over right away and checked to see if there was any visual damage, couldn't see too much, but driving home I noticed it definitely didn't feel the same!
The alignments all out, the steering wheel now wobbles like a b*tch and there's a knocking sound coming from the back! NOT HAPPY! >_<
Fingers crossed the wheels aren't buckled!
Edited by Tommmo
I took a couple of pictures with my phone last night, they didn't come out too good though.
Thought about going back there this morning, but its on the other side of the city for me and knowing my luck they would have filled them in by the time I get there.
i live round the corner, but im at work. ill see if i can get some at some stage tonight or tomorrow.
That would be great! much appreciated..
To the mechanics I go.. fingers crossed its nothing too serious!
all 4 wheels are buckled!!
front are quite noticable, rears not so much.
called the council, apparently they are not responsible for the road works, there's a new development between Blaess Dr and Belperio Cl and the builder is in charge! :)
1: find some bent high end expensive wheels
2: get them for dirt cheap
3: put on car
4: claim they were damaged by the roads
5: ????
6: profit
Hahah.. there's a thought!
Just not my style though
Damnn, i had similar thing happen in my old skyline. i went to turn a corner and there were concrete pieces all over the road, something had hit the corner before, but by the time you see if you've turned the corner and drove all over it!
long story short, i bent my sparco wheel, waited 2 hours for a tow lol :). luckily was fixable though
Edited by Murry33
that sucks!
how much did it cost to fix?
I was told mine are fixable, but at $200-$300 per wheel plus a wheel alignment! i'm not happy!
I'm not paying for someones negligence!
Hate to be the bearer of bad news, but if the above is actually the case, they may use that to waive any responsibility (hazard sign generally means, 'slow down & look').....having said that, if it's as bad as you say, they should have zoned that area off.
And as far as the council not having any liability....huh?!
Even if they are private contractors, I would've thought the council would have to be the overseers of the project.....public road isn't it??
This reminds me of a similar thing that happened to me.
It's amazing how quickly councils and contractors pass the buck to each other when stuff like this happens.
A few years ago I parked in the Elizabeth City Centre car park and put my front wheels against one of those concrete sleepers that are held into the ground with 2 spikes (rio rod).
Unfortuantely, one of the spikes were sticking out approx 6 inches so as I drove forward the spike got hooked under my front bar (didn't even hear it).
When I reversed out it ripped my whole front bar off the car.......consequently my bloke got away.
Tried the Centre Management, didn't want to know me, "council's problem".........tried the council, did't want to know me, "Centre Management's problem".
Went back and forth a couple of times before going into the Magistrates Court and paying $80 for a Letter of Demand which I sent to the Centre's Maintenance Dept and they couldn't pay me quick enough cause I threatened to charge them for a lost day's work as well at $150ph.
I spoke to the council and the contractor.
The council says the contractor has a due care to keep the road in a safe state, which they didnt. According to them, If the road was in a state to cause damage to my vehicle at 50km/h, there should have been additional safety measures, be it signage, patrol, road closure etc.
The contractor said the signage was sufficient and believes road was in a safe state!
They have asked me to send them a copy of photo's and they will review my claim.... I think I already know the verdict!
Clearly the road was not in a safe state with your photos being evidence enough.
You're 1/2 way there....the fact that they've even asked for photos indicates that they are liable for road safety measures as opposed the council.
Now you just have to know how to handle the situation and not take their bluff as gospel or take no as an answer.
 Share
    • The Daily - 2011 Audi A5 And the camper VW transporter T5
    • Wow mate that's huge, congrats. Glad you found better people to deal with and all seems like it's going in the right direction.
    • The best setting for street is what gives the best tyres wear for your driving style Different tyres like different camber You want the whole surface of the tread to wear flat, if the inside of the tyre is wearing more than the outside reduce camber settings For toe, have the minimum amount to give the handling you want Caster, from my experience if you can adjust it, is as much as you can get without clearance issues And while -2.5° of camber on the front might work well with good tyres for "spirited" cornering, it may be too much for a street car Lots of front camber will effect braking Just like to much rear camber will effect rear traction (rwd), and braking  When I set my Bogan Cruise Ship (VX SS) up for drags I tested how much tyre width I actually had in the rear by doing a hard launch (skid), it originally had -1.5° in the rear, and you could see that the tyre wasn't putting down alot of the tread, I maxed out the settings to get as little camber as I could with the OEM adjustment and some camber bushings and got it down to just under -0.5° with 0 toe, that gave me a fair bit more "rubber on the road" and helped it hook up for my 60' and my 0-100kph And with -1.5° in the front the big old boat handles fine on the street and my tyre wear is nice and even on both front and rear tyres (currently Hankook RS4's) As for semi slicks at the track, again, it depends on alot more IRT the suspension, the track and lots of other things, so, I'll leave that up to people who have more experience, especially with a AWD In saying this, street settings are pretty easy, just look at the tyre wear Meh, Necro thread, it's late at night, and I has been drinking beer
    • Thought I'd give an update. There needs to be scarce details in some areas due to ongoing discussions. Here's the journey of trying to make the booked registration appointment (again). Sent a complaint to Car Inspect outlining the concerns and made some demands. Went to a service center in Geelong, got assaulted with bullshit items on the RWC, as you know. Tried to quote $2.5k AND wanted a structural report Only seemed to be one place around Geelong that does them, they demand $495 just to end up telling me it's f**ked, at least $11k to fix and tried to sell me his own Skyline in the process (bro, wtf?) Started stressing about what I'm supposed to do with this possible pile of steel. Awaiting that, I was sent an angel friend who works in Melbourne and knows real mechanics and body shops.  They laughed at the reported quotes (don't get work done in Geelong) Car underwent some front surgery and brought back better They then sent it to the mechanics for RWC Registration appointment is two days away at this point. Mechanics pointed out two issues: driver's seat and shocks - that's it. He offered couple options and I chose coilovers. Frantically I scoured the jungle realm that is Facebook Marketplace (again). Found what looks to be a decent Series 1 seat actually - $100 Guy is friendly, offers to bring the seat with a colleague who's heading to Geelong (thanks man, that was cool) Seat arrived, looks good. Throw it in my car and drive to Melbourne and drop it to mechanic T-1 day, mechanic reckons job will be done for the fronts only, gets it done by 4PM Mechanic heads to get the coil-overs that night as a favour to help me make the appointment Get driven to Melbourne, drove the car back - RWC Unlocked! ✅ VicRoads tomorrow, the goal is close now. 🙂
