1997 white R33 GTST 5 speed manual series 2 coupe
98,000 km's serviced every 5000 with synthetic oil
I am first owner in Australia since 46,000kms
Punches out a streetable 250 rwkw with alot of room for more. Tuned by Adam from JEM at Ingleburn.
Modifications (all parts used were purchased brand new):
ENGINE:
Garrett GT3076 internal gate, low mount
Tomei direct replacement fuel pump
Nismo 555cc injectors
Custom forward facing plenum
Apexi Power FC
Greddy Profec B Spec 2 Boost controller
HKS super Dragger turbo back exhaust
bell mouth stainless dump pipe
High Flow CAT
Z32 AFM
Apexi power intake
Cold air box
Splitfire coil packs
Front mount intercooler
All engine mods have been purposely made to look stock and not draw attention from the prying eyes.
HANDLING AND SUSPENSION:
DBA 4000 cross drilled and slotted rotors all round
KFM racing pads
Braided Brake lines
Tein superstreet coilovers
18" lenso DC6 wheels (not a single mark with near new toyo tread on all 4)
OTHER INFO:
Autowatch alarm and immobilisor installed plus a second immobilisor with pin code installed. Have security certificate for it as well.
Rockford fosgate speakers front an rear powered by sony amp and JVC dvd head unit
Immaculate interior stock looking i.e. power FC and Boost controller concealed
Good paint, no marks some small chips on front bar.
Unlike every other car on SAU this car comes with all stock parts minus the turbo and CAT back exhaust in case it needs to be returned to stock for any defect reasons etc.
STOCK ITEMS:
Intercooler
Injectors
Dump and front pipe
Second Stainless split dump and front pipe (not a stock item)
Plenum
intercooler piping
Brake discs x 4
Air box + snorkel
Coil packs x 2 sets
turbo oil and water lines
4 standard wheels no marks with new tyres
Standard springs and shocks
Standard AFM
Second non genuine z32 AFM
This is a great car and i am so sad to see it go but i must upgrade to a family car with 4 doors and keep the missus happy. I am in no hurry to sell advertising now as the market is slow for skylines and ridiculous offers will not be accepted or considered.
Price is negotiable, i am asking for $17,500 and yes this is slightly higher than most skylines but this car comes with all standard parts worth plenty if sold sperately and peace of mind you have the parts required to pass defects if any.
Please only serious buyers and NO ridiculous offers, if you have any opinions with regards to price please keep them to yourself, there is alot here to justify the price tag. I am a genuine person and hope to find a genuine buyer.
Car must be seen to be appreciated.
Location is Southern Sydney Cronulla region or Singleton (1 hour west of Newcastle)
Contact me 'Peter' on 0405372880 or alternatively PM me
FOR ALL OF THOSE OUT THERE WHO ARE THINKING I WONDER IF HE WILL SEPERATE PARTS ESPECIALLY THE STOCK ONES THE ANSWER IS 'NO' SO DONT BOTHER ASKING UNLESS YOU ARE WILLING TO PAY RIDICULOUS AMOUNTS OF MONEY FOR THEM.
https://www.sau.com.au/forums/topic/267317-eoi-1997-r33-gtst/
  • 3 weeks later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
