Just ordered 2 Vipec plug-in ecus and 5bar map sensors and expansion loom on monday, they are going for $1765, and $187 for the map sensor and $70 for expansion loom.
you can use the stock knock sensors or aftermarket ones doesnt matter, but you will need a knock amplifier for either, unless you get the V88 version which has the amplifier built in. the V88 goes for about $2500~
hmm shoulda called i had a few spare of same package in link for $1750 or the 2.5bar setup was $1650..
Edited by URAS
why would you ever risk your hard earn $ and time and run a std ecu?
if you cant run it properly, dont run it at all
too often we see guys spend $$$$
put a stock ecu with heaps of mods
cos they cant be assed waiting
they load it up and bring it on boost
and cause damage
youve been warned
I am well aware of what can happen, I am also aware of what my right foot is doing when I'm driving the car.
    • There was a great one on Victoria Rd in Gladesville too back in the day. I can only assume GTSBoy is thinking of the mill up on the wollondilly, no restaurant there any more but they have restored the original steam engine on site and run it every few months, have an annual steampunk festival etc @The Bogan, you came to the wrong town for restaurants. we have a few reasonable asian and indian options but the Paragon is as good as it gets otherwise. That brewery is apparently just opened, been meaning to give it a go some time. The Highlands have plenty of fancy options but I suspect you are more a hearty eater than fancy eater
    • Thanks for coming back to post the update, maybe it will help out the next person!
    • Going by the intake & injectors I'd be guessing it's a DE, check the head casting number, should be 5L8 on a DET, 5L7 I think is the DE number.
    • For future reference, if you need to use Deutsch connectors but don't have the proper crimper for the round style pins, you can get regular style crimp pins too
    • No. The castings are all the same. As you have the inlet off, simply measure the diameter of the inlet ports and compare with the freely available on the net sizes of turbo and NA. The NA ones are small.
